Automotive Monomaniac
Emission's Avatar
Rubber bumper melted to valance (pic)... how to clean?
My rubber bumper is melting/melted on my rear valance. (Track use gets the turbo glowing, and the PO bent the muffler back so I think it contacts the valance transferring the heat.)
In any case, I have a new muffler and I want the valance cleaned.
What do I do to get it back to "new" again? Strip and repaint? Chemicals? Buy a new one (where)?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-03-2005, 03:13 PM
Junk both of them and repiant the bumper. Looks better anyway.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 05-03-2005, 05:02 PM
Emission's Avatar
Remove the valance forever? I've got too much crap down there that needs to be hidden...
I see Pelican sells one for $124 (part C-505-171-08-GRV). It appears single outlet.
Does anyone sell replacement steel valances (dual outlet)?
Old 05-04-2005, 09:20 AM
Carefully scrape the melted rubber off. If lucky, the use of progressively less abrasive polishes wil bring back to new.
Or just unscrew, sand down and buy a can of color matched paint from www.towerpaint.com and respray.
Warren & Ron, may you rest in Peace.
Old 05-04-2005, 09:25 AM
Information Junky
island911's Avatar
Are you sure that isn't some other sort of goo?
I believe those bumperetts are a thermoseting foam. (shouldn't melt . ..burn or charcoal maybe, but not melt)
Old 05-04-2005, 09:30 AM
Par911's Avatar
I think he was recommending to get rid of both of the huge rubber bumper pads, and paint the bumper, then mount it without them. I also prefer this look, it is much cleaner IMO.
Sand down the melted rubber until it is smooth with the bumper.
Old 05-04-2005, 09:35 AM
i have the same "melting" issue with my rear bumper, though it's on the passenger side. the black bumperette is pulling away from the bumper a little in the same location.
Tim
'06 Cayman S
'96 993tt
'87 930 (gone, but not forgotten)
Old 05-04-2005, 09:37 AM
Emission's Avatar
Ah, that does make sense. Great idea ~ but not this time. I will eventually need the front and rear bumpers sprayed (from rock chips), that will be the time for removing the black blocks.
Old 05-04-2005, 09:50 AM
Emission's Avatar
It's bumper. I even mounted aluminum-faced fiberglass heat shield to prevent more damage. It helps, but man it gets HOT down there.
Old 05-04-2005, 09:51 AM
