3 restos WIP = psycho
kenikh's Avatar
The beaten horse - 911L differentiating factors (motor only)
What are the factors that differentiate the 911L from earlier/later S? I am getting conflicting info from other threads. The pistons were apparently cast and the heads smaller 'T' types, but that is the only thing the other threads agree on.
Were some aluminum cased and some magnesium? Was the crank counter-balanced and were the rods nitrided? Inquiring minds want to know...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-03-2005, 08:11 PM
Sumotang's Avatar
'L' is for luxury and 'S' is for Sport.
Thats the limit of my knowledge. (Very Limited)
Damo
83SC 'Guards Red' - Sold
1994 993 C4
Old 05-03-2005, 08:21 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
What was the T for??
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 05-03-2005, 08:35 PM
Sumotang's Avatar
'T' is for Terrific
Damo
1994 993 C4
Old 05-03-2005, 08:47 PM
DP935 member
kycarguy 935's Avatar
Turbo...lol...just kidding
T is for touring
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 05-03-2005, 08:48 PM
Well, I know my car (will be) is terrific, that's for sure! hehe
Matt J.
Old 05-03-2005, 08:49 PM
.........does this mean that you got your car???? we are waiting for the pics......patiently!! maybe not. from what i read in the peter morgan book, starting in 1967 the 's' models had nitrited connecting rods and forged pistons. the 't' models had had 'cheaper' cast iron cylinders due to their reduced stress with a lower compression ratio. it was unclear in the book whether or not this still was the practice going into 1969 when they changed the case halves to magnesium from aluminum and started with the glorious MFI era. for what it is worth, from what i got out of the book, it was differences that went from compression to makeup of cylinder walls that made the differences in the model designation. hopefully somebody else with a much deeper history knowledge will enlighten us all!
drive the convertible when it is not raining....my it sees a lot of time in the garage in Seattle!
'91 C-4 Cab 3.8 fun machine.
Old 05-03-2005, 09:01 PM
kenikh's Avatar
YUP.
The next goal is to have the 2.0L buttoned up, then get it outta the car since it is a numbers matching motor and get another motor in the car I can beat on.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-03-2005, 09:07 PM
..........sweeeeeeet. that's what i'm talkin' about. you better not put your address anywhere i can find it....!!! did you check the back of your case yet by chance to see if the drive sprocket is there for when you find your MFI for it? nice car ken.....very nice!
Old 05-03-2005, 09:11 PM
kenikh's Avatar
Not yet, but I will. I found an original '69S MFI and need to start hinking about how muchn work it will be attach it. I can't tell how original the engine bay is yet.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-03-2005, 09:14 PM
.....it actually is not that much work to attach it, as long as the top of your original engine was not changed much when the carb conversion took place. as long as the studs to attach the pump are still there, the plugs in the heads for the injectors are easily removable, the cams are still the original with the drive sprocket attachment(!), and you have all of the hardware needed, you could easily prep it to get dialed in by a local expert. nice car!!!
Old 05-03-2005, 09:22 PM
kenikh's Avatar
Do you still need to see the motor, BTW?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-03-2005, 09:24 PM
........i will check it out at the show and shine! your motor may be too clean to see what i am looking at....the glare may blind me. what i wanted to see and will check out when i see your car is just the clearances and location of the control board for the mfi etc. in the engine compartment. catch you next weekend!
Old 05-04-2005, 08:20 AM
kenikh's Avatar
I got confirmation on the case differences for the 'L'. Mid year switched to Mag from Al. Have yet to find what engine series number was the last aluminum case, but will research further. It also appears the 'L' engine was identical to the 'T' which most likely means an NCB crank.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-04-2005, 09:48 AM
