Weber carbs
Looking for a shop thats rebushing's the carbs.And where do you draw the line as to when they are JUNK.Can they be recoated on the inside to save them?Whats the cost involved in this?
THX
RT
Old 05-04-2005, 05:32 AM
jluetjen's Avatar
Call Matt at Eurometrix in Groton MA. Do a search on "Eurometrix" here on Pelican and you'll find a link to his web site that has been published here before.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-05-2005, 02:53 AM
ttweed's Avatar
There is also Bieker Eng. on the west coast. See this thread for contact info.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 05-05-2005, 06:25 AM
jluetjen's Avatar
Here's the Eurometrix contact information.
228 Boston Rd
Groton, MA 01450
Tel. 978- 448 2557 (Matt Blast )
John
'69 911E
Old 05-06-2005, 03:36 AM
Hey guy's thanks for the information.This is for my 69 911E also.
Old 05-06-2005, 06:03 AM
Kevin Taylor's Avatar
THX
RT
1) My driveway.
2) Right Down The Middle
3) Spray Paint The Insides
4) Case Of Mick
K.T
1973 911 E 2.4 MFI
1983 911 SC
1997 GMC SIERRA Z-71 4x4
2000 JOHN DEER LT 166 TRACTOR
1965 DEVIN "D" - 1967 912 POWER PLANT
Old 05-06-2005, 10:49 AM
I am rebuilding my Weber 40IDAs (4) in my 512 Boxer right now.
The carb kit I am purchasing (royze brand) includes 2 throttle bushings which are press fit in, I am apprehensive to dissassemble the throttle shafts as if you don't get them exact you will wear your intake bores out, my shafts make a slight clicking noise at idle but were not leaking air as I sprayed carb cleaner in the area and it had no effect at idle, when the carbs are apart I can't move the shafts at all so they seem okay in this test also to me.
So how much movement do you have in your shafts is the question?
If the shafts are too worn you can get oversize shafts and have them line bored and rebushed, but I would try the bushing in the rebuild kit first, now I am fairly certain the Ferrari 512 Weber 40s are almost identical to the P 911 other than a few extra progression holes and linkage arrangements but I could be wrong. The kit I bought was for 911s though.
When are they junk?
I would say if your intake bores are too worn from the butterflys wearing grooves in them, this is due to worn throttle shafts/
Rebuilding them is easy, just take your time and be careful and clean, get a gallon of carb dip to soak the bodys and parts in, I would reccomend it as it gives you a good understanding of how the carbs work.
Old 05-06-2005, 11:31 AM
jluetjen's Avatar
Matt at Eurometrix will rebush and reshaft bodies as needed, he also refurbs the butterfly itself so that it fits exactly in the barrel. Call him up and ask he and he'll be happy to tell you exactly what he can and can't do.
John
'69 911E
Old 05-06-2005, 12:05 PM
