Czar of C.R.A.P.
dfink's Avatar
oil cooler seal
Just noticed my oil cooler seal is all but gone. I did a search and found that this is a necessary seal for proper cooling. My question is this; Do you have to pull the oil cooler to replace the seal and also is there an alternative to the $88.00 dollar seal such as foam rope or foam pipe insulation split and slid in.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 06-08-2005, 07:58 PM
GeorgeM's Avatar
I used foam pipe insulation. Works like a champ at 1% of the cost.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 06-09-2005, 02:58 AM
Cymru am Byth
carmad's Avatar
I did the foam pipe insulation, driven in rain many times and still holding up after about 5000 miles. Cheap and easy to replace.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 06-09-2005, 05:43 AM
Czar of C.R.A.P.
dfink's Avatar
Did you use any adhesive or just stuff it in around the cooler. Also do you remember what size you found worked best.
66 912 Coupe
Old 06-09-2005, 12:50 PM
GeorgeM's Avatar
No adhesive. I think I used the stuff for 1/2 inch pipe. I seem to remember that the 3/4 inch stuff was too loose. I doubled it up in a couple of places where the gap was bigger.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 06-09-2005, 11:42 PM
