Hbrand
hbrand's Avatar
1985 Porsche engine suddenly shuts off
This car gets on my nerves.
Engine just shuts off during accilerating. During coast down in gear all gauges still show l normal values, shows RPM, coil gets power, fuelpump keeps running. Checked for bad contact, replaced Motronic unit, checked air flow sensor, disconnected cruise, rpm and others - still the same. Fuel pressure is 35psi and a lot of flow.
If engine did shutt off, just turning the key quick over and ignition on does not start the engine. Using the starter starts the engine.
Could that be something in the tank??
Thanks, harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 05-07-2005, 05:45 AM
Nine9six's Avatar
Perhaps you have a failing/intermittant DME relay which is located under your drivers seat, next to the DME.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 05-07-2005, 07:30 AM
