-   -   H4 install question: (http://forums.pelicanparts.com/porsche-911-technical-forum/220260-h4-install-question.html)
speeder 05-06-2005 09:02 PM
Putting H4s into a late Carrera that had H5s, does anyinie know which wire goes where?
There is a brown one, a blue one and a yellow w/ red stripe. As usual, the search function is failing me so any help is appreciated. TIA. :cool:
ianc 05-06-2005 10:46 PM
Now, see, if yez still had that SC, I could lend you a hand. But...
ianc
speeder 05-07-2005 12:40 AM
If I was working on an SC, I wouldn't need a hand because they would just plug in. ;)
At any rate, I wound up doing it the old-fashioned way. I just touched the wires to terminals until the high/low beams worked and then buttoned it up. :cool:
stefang 05-07-2005 07:47 AM
Brown is neutral. yellow is low beam
on the socket -
56a is the high beam feed.
56b is the low beam feed.
31 is ground.
Stef
