Suspension squeak
I feel like a dork for asking this....but this car is new to me and the suspension is unlike anything I've ever owned before.
There is a squeak (like a bed spring) in the front left suspension. I can push it up and down in the driveway and it'll just squeak to beat the band. Removed the wheel to look it over....nothing looks out of place. Any ideas what I might look for? TIA Aaron
1978 911Sc Talbot yellow |
Stranger on the Internet
Do a search for suspensionn bushings or control arms. Your bushings are likely shot, and you may have a metal to metal rub (but that is not a certainty).
Pat
Patrick E. Keefe 78 SC |
timeless beauty
I had a squeak on the right side, sprayed silicone on rubber bushing all of them and litho grease, DO NOT get any on your rotors. It took a couple of times and its gone.
Bob 87 targa |
Thanks guys......now I have a starting point.
It'll be legen-waitforit
Also could be ball joint, take a hose and hold it up to your ear and put it near each part of the suspension as you push down, and you should isolate where the noise is coming from.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Dont feel like a dork for asking. This is the only place you can !
Interestingly, I had exactly the same squeek in my R front .. I was about ready to rip the whole assembly to pieces but I tried this : 1) Adjust the ride height bolt by turning the bolt 180 degrees cw 2) bounce the suspension up n down a couple of times 3) adjust the ride height bolt back to where it was before (ccw 180 deg ) Don't have a CLUE why this sorted out the squeek but I am not complaining ! ( Just hope this post hasn't jinxed me ! )
1987 ROW Carrera Targa, SW chipped 1983 U.S.A. SC coupe ( bro has her now ) |
