-   -   Replacing syncro rings- What else to do while I'm in there?? (http://forums.pelicanparts.com/porsche-911-technical-forum/220494-replacing-syncro-rings-what-else-do-while-im-there.html)
84Carrera911 05-08-2005 05:18 PM
Soon I'm going to be replacing the syncro rings on my 84 Carrera, and I have a case of while I'm in there syndrome. I was wondering about some other upgrades I could do while I'm in there. I was thinking the wevo internal gated shifter and the coupler. Does anyone have any other ideas? Thanks,
Tommy
johnsjmc 05-08-2005 06:20 PM
If you are doing the rings because 1st or 2nd grinds you will also need the syncro teeth on the crunchy gear(s) and probably the 1-2 slider.If 3 or 4 are problematic add a 3-4 slider and 2 rings if 3and4 are OK now just new rings for them 5th rarely needs anything other than a ring. I have heard good things about the wevo products but have no first hand experience.
Elombard 05-08-2005 07:19 PM
Only things I can think of are add a cooler, LSD. Oh there is some reinforcing plates for the diff and some other reinforcing plate that Wevo makes. Mostly geared toward the racers I believe.
84Carrera911 05-08-2005 08:22 PM
Actually the car just plain will not go into second gear. Third gear grinds occasionally, and fourth and fifth are fine. I can't go into first unless I'm at a complete standstill, is that normal?
Thanks,
Tommy
johnsjmc 05-10-2005 06:36 PM
You probably need 1 and 2 dog teeth, 1/2 operating sleeve(1/2 slider ) and 1st thru 4th syncro rings add 5th ring for good measure and a gasket set and 2 new mainshaft lock nuts All fairly typical
Muf 05-12-2005 05:45 AM
I am about to do the same on my 79 SC.
My problem is that in a certain rev range (from about 4 - 5 thousand) the second gear grinds (shifting from the first).
I have no problem inserting the first when the car is moving or inserting the 2nd from the 3rd etc.
I have already bought the 2nd synchro ring (this needs to be changed anyway) and I think the rest will be obvious when we open the transmission... Should I get anything else which definitely needs to be changed?
PS What causes the 5th gear to whine?
