Senior Member
ohecht's Avatar
"street lightened" 3.0 flywheel?
I noticed in Wayne's rebuilding book, in the part of machine shop service prices, the "street lightened" flywheel, with 1/2 pound removed.
Can anyone running such a flywheel let me know how it drives?
The car is a daily driven SC, and I am looking for slightly faster response and an easier load on the engine if it is worth it and doesn't compromise street driving.
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 12-15-2003, 04:23 AM
Senior Member
ohecht's Avatar
Anybody done this?
Olivier Hecht
1982 911SC
Old 12-15-2003, 02:28 PM
The aluminium pressure plate (sachs power clutch) is several pounds lighter I think I read as much as 8 lbs . I used one in my 86 a few years ago. It reved up and down noticably more quickly.I personally would only remove enough material from the flywheel to restore the surface and buy a new clutch assembly if in there anyway . John
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 12-15-2003, 07:17 PM
9elf's Avatar
I am thinking about an aluminium flywheel and an aluminium sach's pressure plate. What do you good gentlemen think about the potential performance increase?
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 05-08-2005, 06:28 PM
randywebb's Avatar
the potential performance increase = 0 (or really, = the same as taking that much wt. off of your rear seats or something like that)
What you will get is more feel of "revability" - but since you have CIS (right?) on your '77, that will impede throttle response.
So if you need to change anyway, it makes some sense. But not to do it if your clutch is not worn - unless you are going to redo teh entire engien with carbs or MFI or aftermarket EFI, exhaust etc. ....
Sorry to be the bearer of bad news.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-08-2005, 08:48 PM
9elf's Avatar
Thank you randyweb. I did think an additional 200 hp was a bit optimistic.
Old 05-08-2005, 08:51 PM
randywebb's Avatar
Time for the PMOs, cams & SSIs...
Old 05-08-2005, 09:22 PM
350HP930's Avatar
Since the light pressure plate assemblies for a 930 are quite expensive and I have access to a machine shop and balancing machine I removed a couple of lbs off my clutch assembly for free. I'm too cheap to spend a lot of $$$ on crisper throttle response and negligible improvements in acceleration.
Before
After
Old 05-08-2005, 09:23 PM
Porsche Head's Avatar
I have the Sach power clutch in my 3.0 with a 7:31 rp and it revs up real quick, works best on lower gears because that's when you are accelerating the mass (less) the most. By 4th there isn't much difference.
I also have a 12lb alum flywheel on my BMW M5 and it made a realy nice change as well however the RPMs drop pretty quick between gear changes but still idles smooth.
Cliff
1972 911E w/3.0 RS Replica
1988 M5 300hp
2016 Audi Q5 TDI
Old 05-09-2005, 10:37 AM
