steven c's Avatar
1981 911SC galled top nut on Boge Strut
Was taking apart my right front Boge strut for Koni inserts and galled the top nut and body threads terribly unscrewing it. Cannot get the new Koni nut in further than maybe 2 threads. Is there a solution for this other than finding a good used strut?
Left strut came apart just fine......
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-17-2025, 05:25 AM
Pictures please……..
Could you post a picture of your problem? Thanks.
Tony
Old 11-17-2025, 05:44 AM
steven c's Avatar
Sure, the old nut on the right and the new Koni nut on the left. The interior threads in the strut look just as bad....
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-17-2025, 05:52 AM
Try to find a big tap.
Old 11-17-2025, 07:19 AM
steven c's Avatar
I do not even know where to start on that, not many ship builders around north Texas. Thanks
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-17-2025, 10:40 AM
Take the old nut from the other side and cut 3 or 4 slices across the threads just to the bottom of the threads clean it up on with a wire wheel and use it as a clean up tap go slow and use plenty of spray oil It will clean up the internal threads
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 11-17-2025, 10:41 AM
steven c's Avatar
The better nut from the left one goes in but very tight so this might get me where I need to be. Great idea, now to the Dremel tool for the cuts. Thanks!
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-17-2025, 10:44 AM
Hi
Post #6 is a good option, alternatively, suggest you obtain the correct pitch thread file and use it to clean up the damaged threads in the strut.
Hope this helps
Cheers
Old 11-17-2025, 11:35 AM
If the nut starts to thread in you could add some valve lapping compound to the threads and work the nut back and forth multiple times until it threads in. This will take some patients.
Old 11-17-2025, 01:25 PM
steven c's Avatar
Lapping compound I may be at next. The one good original nut, after slicing into the threads, now fits very loose and the Koni nut is only in maybe +/- 1/2 another thread. So no more benefit from it.
Trying to buy a second Koni nut before I slice cuts into the one I have to help it cut a path.
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-17-2025, 01:42 PM
911 Ft Strut, Gland Nut, Koni into Boge, SS 304, $28.22
Old 11-20-2025, 11:05 AM
