No Spark here.
After 3 or 4 months of trouble free driving my 930 died at idle last weekend. I have no spark. Elect is not my strong suit, so i'm in need of advise. CD box whines, connections from 6 prong plug all seem ok, and tested for "buzz" at all ends of the wires. Discon the tach, no change, had coil checked, tested ok. I put in a new/used distrib a few months ago. Is there any test for dummies of the distrib in the car via the green wire? Or a test to show power to the distrib and out of it. Or other items to test? Thanks. Brian
Old 05-10-2005, 06:12 PM
ruf-porsche's Avatar
Do you still have points? Check the Gap
Old 05-10-2005, 06:22 PM
I think it's pointless.
Old 05-10-2005, 06:23 PM
What year is your 930 Turbo?
Old 05-10-2005, 07:19 PM
78
Old 05-10-2005, 07:28 PM
Registered abUser
TerryH's Avatar
Is the distributor rotor turning? Seems the dist. would be suspect, but hate to assume anything at this stage.
'81 911SC Coupe SOLD
Old 05-10-2005, 08:08 PM
I'll check the rotor. I suspect the distrib also, but don't know how to test. Thanks.
Old 05-11-2005, 05:11 AM
David's Avatar
Check that you're getting a signal from the green coax wire coming from the distributor.
Old 05-11-2005, 05:39 AM
Registered abUser
TerryH's Avatar
Here's a thread I read yesterday on some ignition troubleshooting.
CDI Help
Old 05-11-2005, 06:42 AM
Thanks. I know my coil works, I had it bench tested. But, I am going to pull the cap and rotor tonight and replace. Rev limiter has been making a diff sound for a while now. Still not sure if the problem is upstream from the coil.
Old 05-11-2005, 09:28 AM
Are you sure you are not getting a spark?
Old 05-11-2005, 10:09 AM
Yes, I have no spark. and I just pulled the cap and rotor. They look ok, but i am replacing.
Old 05-11-2005, 10:17 AM
