Black and Blue
Steering Rack seems a little rough...
I have noticed that when turning sharp, either way, the wheels dont straighten out much like they used to upon exiting the turn. I have to physically turn the wheel back to straighten...
is there any rememdey other than yanking the steering rack and replacing with a rebuilt one? thanks
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
You could grease the rack, but the rack may not be the cause. You have to check all the components for wear, loose fasteners, and lubrication.
'80 SC |
Lift the front wheels off the ground and see how tight it is to turn (via the roadwheel) from lock to lock. If it feels tight remove the steering u/j from inside the smugglers box, and try again. If its easy to turn now(again, from the roadwheel) then the problem is a siezing steering u/j. If it is still tight then it is either the rack itself or a sticking/binding track rod end or lower ball joint.
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
