Paint Type? 86 Carrera Grand Prix White
I am ready to have a couple panels stripped and repainted. The car is orig paint - Grand Prix White. The first place I went to thought they would do a base - clearcoat job. I was under the impression this was not the type of paint used.
Is a single stage enamel the same as the orig?
If not, what was the type used?
thx
todd
86 coupe
Old 05-11-2005, 08:59 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
An '86 should be a two stage paint from the factory. If for some odd reason it isn't your going to have a hard time getting any acrylic enamal now days. I'm not sure about Tucson but here in So Cal it isn't even available anymore.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 05-11-2005, 09:15 PM
Thanks Kevin
Since I am not knowledgeable on paint and just so I have the terminology right, when you refer to two stage, you are referring to base coat - clearcoat ? Is that the type for all finishes [i.e., opaque as well as metallic]?
thx
todd
86 coupe
Old 05-12-2005, 07:01 AM
MAGA
Tim Hancock's Avatar
FWIW, PPG Delstar and Dupont Centari are both singlestage paints that are easy to use and readily available (I just bought and sprayed some PPG Delstar on my GP White 911 recently). These are not the highest tech paints nowadays, but both have been used for a long time to spray many a car.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 05-12-2005, 08:31 AM
