H-4 lenses
Can these be bought somewhere? Mine are getting tired looking. I even thought of buffing them out but don't know what kind of buffing compound would work on glass.
I've done it to plastic lenses before and they came out great. Anyone know of a place to buy them?
Silver 1980SC Euro coupe |
Bosch H-4's ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Will program for food
Our host sells them - try this link. But I do not think you can buy just the lens.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_911REC_pg5.htm
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Check our hosts site, they might carry them. If not try Ebay I always see them there.
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
I was looking for just the lenses. H-4 Bosch
Ron,
Check out Ebay if you just want the lens .
Me like track days
$25 is CHEAP - for 2
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Be sure the replacements are glass and not cheapo Plastic.
Both are available, glass being more expensive. They comer up on Ebay fairly frequently, both types.
1985 Carrera 2000 Tacoma TRD 4x4 Supercharged 1984 Harley Shovelhead Wide Glide Last edited by WilliamJ; 05-12-2005 at 12:36 PM.. |
Good luck.
1985 Carrera 2000 Tacoma TRD 4x4 Supercharged 1984 Harley Shovelhead Wide Glide Last edited by WilliamJ; 05-12-2005 at 12:38 PM.. |
Pelican sells the relacement lens. Not sure if it's plastic or glass, but the part number is: 1-305-614-005
'99 996~LSD~VE Wheels~H&R Cup Kit~Aero~Recaro~X51~M&K~GT3 Roll Bar '77 911 ~ very modern running gear ~ Gruppe B...the Midwest motorsports playground |
And don't get fooled by the pics in the evilbay ad. They look yellow because they are on yellow boxes. They are clear because that's all you can get in glass for the H-4 is clear (not that you'd want yellow
)![]() BTW, those are plastic and to be mostlly used at the track for their relative safety and light weight in that they don't want to shake the assembly loose and fall out. That happens. Last edited by Zeke; 05-12-2005 at 03:48 PM.. |
Ron,
Pelican's part is the genuine Bosch glass lens ... comes in the yellow & red Bosch box! You will probably need the rubber seals for the glass as well ... grouped with the lens in the pPelican catalog!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Insert Tag Line HERE.....
I got mine from Pelican.
Marc |
Thats strange. Pelican was the first place I looked and only saw the complete H-4 units.
Thanks for the part# I'll give them a call.
