Spring Plate Bushing Replacement
I was advised when I have the PPI done on my '83 SC that I should replace the rear spring plate bushings. There are a lot of great threads on the subject so I feel well armed to take on the task.
The question I have is this - what else can I do that does not require that much extra work? Is there anything complementary I can do?
Old 05-21-2005, 11:08 AM
Somewhere in the Midwest
MotoSook's Avatar
If you are just doing the rear spring plate bushing...no...not really. You might replace the sway bar bushings, but that's about it for the stuff that "does not require that much extra work."
Old 05-21-2005, 11:26 AM
Bird. It's the word...
Fishcop's Avatar
It's an ideal time to change Torsion Bars if that is on your plan of upgrades, otherwise as Souk says, there's not a whole lot more to that aspect of the car.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-21-2005, 05:00 PM
Used Up User
imcarthur's Avatar
New rear shocks are an easy install & you're half way there once they're off the trailing arm (ok, that's the easiest part, I know).
Ian
'87 Carrera Cab
Old 05-21-2005, 05:27 PM
Chuck Moreland's Avatar
Yes, the torsoin bars. You might also do the trailing arm inner bushing at the same time. And while you've got the trailing arm out, might as well replace the wheel bearings.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-21-2005, 06:55 PM
Retired Member
Charlie V's Avatar
once you open up the suspension this far....do everything you need to do. Torsion bar upgrade, all bushings, wheel bearings. I did this for the rear and front. Because this is all changed, drop the car to Euro specs, get a good wheel alignment and corner ballance. It is going to cost you, but the end result is a car that has the feel and track of a new one. My feel is that it is worth it.
Old 05-21-2005, 07:04 PM
Zeke's Avatar
What Charlie said. Absolutely.
Old 05-21-2005, 07:23 PM
Great advice. Thanks everyone.
Old 05-22-2005, 08:42 AM
