Bone Head Question
What is the secret to mounting the nuts [not that, you sicko!] for
the emblem on the front trunk lid?
I told you it was a bone headed question!
Drums
'89 G50 w/ 3.6 V-Ram-now Ca. legal!
FORMER Yosemite Chapter PCA V. P.
Old 05-14-2005, 06:09 PM
I think you take a deep drive socket and stuff it with enough plastic, paper, or other till only the nut fits in the socket.
Old 05-14-2005, 06:17 PM
Zeke's Avatar
They should be flange speed nuts which will *ride* on the rim of the socket. But, that comes from the 914s and earlier 911 cars I have owned. Maybe the newer badges have threaded studs? Still, a flange nut is going to work better.
Old 05-14-2005, 06:34 PM
The badge [emblem] is non-threaded.
Drums
Old 05-14-2005, 06:37 PM
My bad. Maybe they are non-reusable?
Old 05-14-2005, 06:38 PM
I thinks so....it's just really tough getting them down in the hole and hitting the post. My needle nose pliers won't go down all the way into the hole, they are too wide and stop short of pressing the nuts all the way onto the shafts. Longer needle nose pliers?
Drums
Old 05-14-2005, 06:47 PM
No, deep drive socket.
Old 05-14-2005, 06:59 PM
ausdilecce's Avatar
Yep, deep socket and try using a screwdriver socket handle rather than a regular socket handle. Better 'feel'.
Leave the needle nose pliers in the toolbox.. They will NOT help you here
1987 ROW Carrera Targa, SW chipped
1983 U.S.A. SC coupe ( bro has her now )
Old 05-15-2005, 01:32 PM
Thanks Guys!
Off to give it a try....
Drums
Old 05-15-2005, 03:59 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
metric nut driver, ie craftsman.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 05-15-2005, 04:49 PM
