Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
In memory of Warren Hall (Early S Man), 1950 - 2008.
[Click for more details]
banner
Back in Cali
Tyson Schmidt's Avatar
Another great WEVO product: rear swaybar mounts
Here's a pic by pic blow of a little project on a 993 bodied racecar that had pulled the swaybar mounts, despite being reinforced.
Here's a shot of the old mount after removal:
Here's the area prepped for the new mount:
The WEVO cast steel mounts bolted to the swayber ready for fitting:
The 32mm swaybar tucked up as tight as it can go with just enough clearance:
The mounts in place, ready for welding:
R-Gruppe member #382
'69 911E coupe' 3.2 (PRC 911-Spec racer)
'92 C2 Cabriolet
'90 C2 Coupe Euro RS clone
Old 05-13-2005, 05:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Light,Nimble,Uncivilized
Tyson,
Nice work. Please post pic's post welding. Miss ya up here dude.
Drago
'69 Coupe
R #464
Old 05-13-2005, 05:35 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Bird. It's the word...
Fishcop's Avatar
How does price compare to factory units?
John Forcier
69 911S/T (interpretation)
2.7 RS powered, and 915 boxed "Bastard"
Restoration of my 69 911
My car proudly fuelled by Early-S-Man's advice - RIP Warren
Old 05-13-2005, 05:38 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Licensed User
Shuie's Avatar
whooooohooooo!
WEVO keeps making parts that I need to replace.
General sway bar mount install question:
How do you line these up once the old ones have been cut out?
Old 05-13-2005, 05:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Back in Cali
The mounts all welded up:
The mounts are superior, due to the fact that they aren't made from thin stamped sheetmetal, but rather a beefy cast part. The threads are tapped into the thickest part of the mount, and there are substantial reinforcing ribs to transfer the energy to the chassis without flex. It's that flex that fatigues the stock mounts, and leads to failure.
You'd break the chassis before you'd break these mounts. And they weigh very little more than the typical mounts that have been heavily reinforced by welding in extra brackets.
The beauty of these is the time saved, and the joy of never having to worry about going back at a later date to fix cracks and tears. Something that usually happens with even the reinforced stock mounts.
I give them the thumbs-up. Great job Hayden!
'92 C2 Cabriolet
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Back in Cali
The factory reinforced units are almost as much as Hayden's WEVO units. It's money very very well spent. These are definitely a one-time expense.
'92 C2 Cabriolet
Old 05-13-2005, 05:44 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
But you are welding them to sheet stock right? I'd be checking for cracks anyway as those beefy cast parts are transfering load directly into sheet metal, albiet over a somewhat larger area, but still.
Drago
'69 Coupe
R #464
Old 05-13-2005, 05:45 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Back in Cali
Originally posted by Shuie
whooooohooooo!
It's quite simple, really. The shape of the mount matches the the shape of the bump on the chassis. There are ribs on the outside that meet up with the seam on the bottom of the chassis.
It helps to bolt them on the swaybar, and hold them up in place like I did on this car. It will all make sense once you get after it.
'92 C2 Cabriolet
Old 05-13-2005, 05:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Back in Cali
Yes, but it's 3 layers of sheet. I also seam weld much more area than the factory did. Almost the entire perimeter of the mount. If you saw it in person, you'd see where it gets it's strength. (The mount-to-chassis union, that is.)
'92 C2 Cabriolet
Old 05-13-2005, 05:50 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Should have known...my bad. Good work T.
Drago
'69 Coupe
R #464
Old 05-13-2005, 05:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Adrenaline Junkie
Hayabusa's Avatar
I looks beefy. I wish I had a pic of the before mount. Was this bar (22mm?) mounted to the above stock mounts? Breaking the mount free?
Old 05-13-2005, 06:01 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
When will they be on site?
'80 SC
Old 05-13-2005, 06:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
Back in Cali
Yes, that bar was mounted to the stock mounts. It's a 32mm hollow bar. The old mounts were reinforced, but whomever did the work, neglected to tie the bracing into the nuts. That's why you can see in the first pic how the nuts just tore right out of the mount.
If you look at the WEVO mount, you can see how beefy the portion is where the bolts thread in.
'92 C2 Cabriolet
Old 05-13-2005, 06:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Fishcop's Avatar
Well I was saving for the new 901 gearbox cross-member anyway, might save just a little longer and order these mounts as well!
Great stuff (as usual) Hayden.
John Forcier
Old 05-13-2005, 06:35 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
Adrenaline Junkie
Hayabusa's Avatar
Definitely stout! I knew that bar was huge. How big is your front bar to balance all.
Thanks for the responce, Tyson.
Old 05-13-2005, 06:58 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Back in Cali
I'm not sure what the front bar is. This is the first time I've seen this car, and I was commissioned to fix the swaybar mounts, and reinforce the torque tube where the 935 spring plates were stressing the chassis.
Dave, my boss, will be co-driving this car in an enduro with the Alfa Romeo club. It's a 993 bodied SC chassis with a 3.8, and ERP suspension all around, including coil-overs. Pretty sweet car.
'92 C2 Cabriolet
Old 05-13-2005, 07:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
'80 SC
Old 05-13-2005, 08:05 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
Back in Cali
You mean on the WEVO website? I don't know. We've already gotten them from Hayden, so I assume if you call him, you can get them.
'92 C2 Cabriolet
Old 05-13-2005, 08:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
The Chef's Avatar
Sweet! My drivers side mount is trashed. Might be a good option if the price is right.
Joe H.
Viper Green 73 RS Light Weight
2100# WET! And getting lighter!
"EVIL GRUPPE" MEMBER 002
Old 05-13-2005, 08:45 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
The Chef's Avatar
BTW. TO EVIL!
Joe H.
Old 05-13-2005, 08:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
