-   -   Is my engine cooling effected...... (http://forums.pelicanparts.com/porsche-911-technical-forum/221407-my-engine-cooling-effected.html)
scca_ita 05-14-2005 11:23 AM
by the gap in the fiberglass engine tin on the left shown in the picture? This is my 3.6 engine that is using early cross member and fiberglass engine tin. There is a rather big gap as you can see in the left of the picture. Should I cover this area like the right side for better cooling or is this not a problem?
http://forums.pelicanparts.com/uploa...1116094929.jpg
dean 05-14-2005 06:53 PM
If it were me I would cover it.
patkeefe 05-14-2005 07:55 PM
Where does the oil cooler go on a 3.6? Shouldn't it be over there somewhere?
Steve@Rennsport 05-14-2005 07:58 PM
Pat:
3.6 motors do not have engine-mounted coolers; there is a pressure side oil filter mounted in its place.
Bill Verburg 05-15-2005 03:59 PM
Yes, it needs to be sealed, it should be something like this 964
http://forums.pelicanparts.com/uploa...1116197833.jpg
Only the 993 has a filter there
http://forums.pelicanparts.com/uploa...1116197963.jpg
scca_ita 05-15-2005 04:07 PM
Thanks Bill, I will cover the gaps......
