Rick Lee's Avatar
Who has solid motor mounts?
Just installed the billet solid motor mounts in my SC yesterday. Didn't have time for a test drive, but just wondering what to expect. I know they make shifting crisper in the 993. How about in an SC?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-13-2005, 08:57 AM
I have stayed with sport mounts on the transmision and Wevos on the rear engine mounts.. more noise is transmited but the shifter is more precise
2006 Cayman S
93 RS America white(now living in Arizona)
1974 911S/CARRERA (now living in Australia)
Livermore Ca.
Old 05-13-2005, 09:20 AM
jwetering's Avatar
Sport mounts at the trans and solids at the rear. Wouldn't have it any other way.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 05-13-2005, 10:52 AM
Rick Lee's Avatar
How much do sport tranny mounts run? Are they easy to install?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-13-2005, 11:03 AM
Monkey Wrench
Spede's Avatar
Are solid motor mounts less effective when used in a cab?
Old 05-13-2005, 11:09 AM
drag racing the short bus
dd74's Avatar
I have solid mounts - and in a hollowed out coupe. Probably the best investment I've made in the car. Tightened up shifting and handling, and with no adverse effects to any componentry (that I know of).
I strongly suggest getting solid mounts. I was having problems downshifting from 5th to 4th, sometimes nicking reverse, and once getting the tranny into 2nd. I thought I needed gate shifters and stuff, but once I changed the shift bushing and added solid mounts, everything improved dramatically. It was like a whole new gearbox.
The Terror of Tiny Town
Old 05-13-2005, 11:13 AM
Mike Bonkalski's Avatar
DD74, did you use the solid mounts on just the tranny, or the motor too?
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 05-13-2005, 11:20 AM
I used sport motor mounts at the transmission & solid mounts at the rear for awhile. It definitely improved shifting a little compared to the worn stock mounts that were in there previously. I found the rear solid mounts to be very 'buzzy' though & switched them to new sport mounts, which transfer less sound to the cabin. Shifting seems equally precise. Anyhting is probably an improvement over 20 - 30 year old stock rubber mounts.
The Unsettler
stomachmonkey's Avatar
I have the solid/sport combo.
More vibration but not intolerable.
Shifting really did not improve all that much but the car drives a LOT better.
Handling is definately better, car does not feel "disconnected" from the drivetrain.
Low speed/rolling in traffic is much improved.
Trade off to me is worth it.
Scott
"I want my two dollars"
"Brandon Won"
Old 05-13-2005, 11:22 AM
dd74's Avatar
Jasper - is there much vibration with solid mounts in the tranny? I've been thinking of solid transmission mounts as well. Did it improve your shifting?
Old 05-13-2005, 11:35 AM
dd74's Avatar
Hi Mike - just the motor. I'm actually inquiring about the tranny mounts with Jasper (from several posts above)?
Old 05-13-2005, 11:37 AM
jwetering's Avatar
Hey dd - I have sport mounts (aka cab mounts) at the trans. Solids at the motor only. I was told the solid trans mounts make for all the noise, but only part of the crisp shift benefits. Kinda like and 80/20 rule. I've never tried this, or rode in anything so quipped.
The solid mounts at the motor on the other hand made a big difference in feel (throttle response and shifting) but the noise didn't increase much. Now I gotta say at the time I was tearingout some interior stuff, and soon after I installed a monster motor so as we speak it's REAL loud in teh car...but not because of the motor mounts. Another point for us carb guys is that Richard Parr (PMO builder) warns strongly against solid mounts on carbureted cars. I aven't noticed a probem.
jasper
Old 05-14-2005, 12:09 PM
efhughes3's Avatar
I just put new sport mounts on the motor, maybe I'm going to get some solids for back there, and put the sports on the tranny...
Who's changed mounts without dropping to motor? Can you just lower the motor and then the tranny ( at seperate times ) to change? Or, do you need to get a little more involved?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-14-2005, 12:13 PM
Jeff Alton's Avatar
I have sports on the tranny and solids on the motor. I will be going to WEVO mounts in the rear. Finding the solids to be a little harsh.
Jeff
www.turn3autosport.com
Old 05-14-2005, 01:39 PM
dd74's Avatar
Jeff
Will your solids fit on the transmission mounts? If so, I'll take them off your hands, Jeff.
Old 05-14-2005, 01:42 PM
350HP930's Avatar
Concidering that stock mounts don't allow much forward or rotational engine movement I think the 'crisper shifting' beliefs are pure placebo.
Old 05-14-2005, 01:57 PM
dd74's Avatar
I noticed an immediate difference, unless my right hand is suceptible to placebos.
Old 05-14-2005, 02:16 PM
PRO Motorsports
Tyson Schmidt's Avatar
BAD idea. David, you won't be able to hear yourself think, and you will worrry that the car is coming apart. Solid mounts at the motor are fine, but at the tranny, they are incredibly noisy!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-14-2005, 02:19 PM
350HP930's Avatar
The shifter hand, much like the butt dyno, is a very subjective instrument.
Old 05-14-2005, 02:20 PM
dd74's Avatar
I have a very objective butt, thank you very much.
Tyson - good points, I'm sure, on top of all the other little rattles that come with a hollowed-out car, I would worry. Question is, can the solid transmission mounts hurt the car? Are sport mounts a better alternative? Or would you leave as is?
Old 05-14-2005, 02:36 PM
