shrouded's Avatar
Send a message via ICQ to shrouded Send a message via AIM to shrouded
Bumper Removal: How?
OK... this should be an easy one. '82 SC. Rear bumper. Whats the easiest/correct way to get this out of the way so I can pull the engine out? (I'm almost finished with my 1st drop!)
Thanks--
1982 911SC - Metallic Rosewood
Old 05-23-2005, 09:18 AM
rfuerst911sc's Avatar
I don't believe you have to remove the rear bumper but if you want to you have to remove the rubber strips,underneath the rubber strips are the nuts that hold on the bumper.You will have to remove one side of the bellows on each side,disconnect your license plate wires and it will come off.
Old 05-23-2005, 09:27 AM
