89carrera relay?
1989 carrera where is the dme/fuel pump relay located?
I have no power at the fuel pump when the key is at the run position.
Old 02-04-2005, 06:21 PM
under the left seat next to the computer. the black plastic unit. wack it with a screwdriver handle and see if it works then.
206 637 4071
Old 02-04-2005, 06:24 PM
Thumbs up 89caeeera relay?
thanks john. i pulled the relay and opened it up. reconnected now have dme relay closes with ignition in run position
but i have to manually close fuel pump relay and the pump
runs but the engine will still not run? i can run the fuel pump manually with the relay but it will not stop running on its own.
Should the pump stop running once pressure has built up in the line.
Old 02-04-2005, 08:19 PM
My 84 carrera has the exact same symptoms. Has anyone found the solution to this problem? thanks
Old 05-18-2005, 06:24 PM
