jakermc's Avatar
WEVO tranny mounts - thumbs up!
The problem - I could not engage 2nd gear when downshifting under heavy load. (On the track)
The solution - WEVO tranny mounts
I replaced just the factory sport tranny mounts and left the motor mounts alone, at least for now. I was out on the track yesterday for the first time since the change and the problem was fixed 100% - not a single missed shift. I have very little sound proofing in my car so noise and vibration did increase considerably, but thats OK on a track car. One of the best upgrades I have made.
I now have the WEVO shifter, battery box, and tranny mounts on the car and every part has exceeded expectations. The Camber King goes on in a few weeks - I can't wait!
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 05-16-2005, 09:46 AM
earlyapex's Avatar
Where did you get the transmission mounts? I didn't see them on the WEVO web site?
I've got their camber plates/carbon fiber strut bar and put in -2 degrees camber without much difficulty.
Eric
1978 spec 911
1998 C2S
Old 05-16-2005, 10:01 AM
Did the same thing (although I replaced all 4 29-year-old mounts), and had the exact same result.
Old 05-16-2005, 10:15 AM
jakermc's Avatar
Our host sells them here:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_911REC_pg29.htm#item
2003 Ferrari 575M
Old 05-16-2005, 10:52 AM
