| Registered Join Date: Oct 2003 Location: UK, Cheltenham
				 |  Front Wheel Bearing Q
			I shall be replacing my front discs this weekend. I have new bearing grease seals and was planning to remove the bearing races and re-pack with grease as part of the job. I'm a little concerned at being able to press the new grease seals in without damage. Without going to the expense of a drift kit can anyone suggest a method for reliably installing these seals? I haven't got the hubs off as yet, so may be unnecessarily concerned! Thanks.
				__________________ "Racing is Life. Anything that happens before, or after, is just waiting" 1988 Carrera 3.2 Sport Coupe - my mistress 2012 BMW F11 touring - the dog bus! 2017 VW T6 Transporter - the holiday bus/workhorse | ||
|  05-16-2005, 01:06 PM |
| Friend of Warren Join Date: Oct 2000 Location: Lincoln, NE
			The seals are made of fairly thick metal and press in quite easily with some light hammer blows. If you are nervous just place a piece of wood over the seal and then use the hammer.
				__________________ Kurt V No more Porsches, but a revolving number of motorcycles. | ||
|  05-16-2005, 01:18 PM |
| Registered Join Date: Nov 2004 Location: Greater Metropolitan Nimrod, Oregun
			watch the angle of the wood block and tap around in a circle to keep it "flat" or at 90o whichever frame of reference you want to think about or use a plastic faced hammer and watch the bearing
				__________________ "A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off | ||
|  05-16-2005, 01:20 PM |
| Registered Join Date: Feb 2003 Location: Black Rock, CT
			I've been known to use a large socket that matched the diameter.
				__________________ Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] | ||
|  05-16-2005, 03:53 PM |
			Thanks guys! As I thought I am unnecessarily concerned! Thanks for putting my mind at ease. I'm really looking forward to getting the car back together as I should have my std spec brakes in as good a condition as possible. I'm interested to see what they are like. In replacing the rear discs, pads and hoses I discovered (as I suspected) a problem with both rear calipers - namely seized inner pistons. I'm awaiting some rebuilt calipers.
|  05-16-2005, 10:43 PM |
