-   -   When to rebuild calipers? (http://forums.pelicanparts.com/porsche-911-technical-forum/221722-when-rebuild-calipers.html)
B D 05-16-2005 02:34 PM
I'll be doing a flush, replacing the pads, inspecting the rotors, and replacing the brake lines but how do you know when it's time to rebuild your calipers?
The brakes work ok, but I have nothing really to compare it to.
MysticLlama 05-16-2005 02:45 PM
On mine it was readily aparent by the dust seals being malformed and pretty trashed, but sometimes they may need it before that.
LakeCleElum 05-16-2005 02:49 PM
I rebuilt mine when they started "dragging" - Not releasing all the way...That was when the car was about 25 years old....This will vary with whatever part of the county you live and if the car is driven in the winter where salt is used on the roads....
Navaros911 05-16-2005 02:51 PM
Like Mystic says; check the dust seals for damage... if any visual damage, replace/rebuild them.
If any pistons are stuck I suggest you rebuild them. It isn't very difficult and doesn't take too much time when they are off the car already.
How to check for a stuck piston: If you're having problems pushing one or more pistons back for the brake pad removal rebuild; the caliper.
Good luck.
- Michiel
B D 05-16-2005 02:55 PM
Thanks for the input. I'll inspect them soon.
anthony 05-16-2005 03:10 PM
Just jack up the car and turn the wheels by hand to see if you notice any drag.
Erakad 05-16-2005 03:12 PM
Also look at the pads, if they're wearing unevenly could be due to a sticking piston or caliper hardware...also trashed dust seals (as mystic said) are usually a tipoff.
Navaros911 05-16-2005 03:16 PM
Why do it the easy way when there's a difficult way... LOL
Superman 05-16-2005 04:36 PM
Re: When to rebuild calipers?
If you don't know when they were rebuilt last, then it's time. A kit costs just a few bucks, and it can be a very easy job. Rebuilding does more than avoid brake problems or improve performance. It also helps extend the life of your calipers.
island911 05-16-2005 05:07 PM
how do you figure, supe?
slater 05-16-2005 07:22 PM
When it came down to my car, I figured if I had to ask, it was probably not a bad idea. For the price of the rebuild kits, it was worth the peace of mind. That may just be me.
ianc 05-16-2005 08:00 PM
the job is not trivial, but the parts are cheap.
For me, I'd say it's time when they start leaking brake fluid, and not before,
ianc
LakeCleElum 05-16-2005 08:10 PM
ianc
They will drag and not release the pads a long time before they will leak!!!!!!!
ianc 05-16-2005 08:46 PM
Hmmm... Good to know. I had three start to leak before they dragged.
ianc
B D 05-17-2005 09:32 AM
Just got off the phone with Pelican and they say there is no rebuild kits for the rear caliper for the 911L same as a 1968 911S. How can this be? What's the diffrence between the front and rear caliper?
LakeCleElum 05-17-2005 09:58 AM
ianc
IANC: Thax for the education. Must be the difference in our climates. Up in the soggy NW, the rust up long before the seals dry out....Take care......
Superman 05-17-2005 10:14 AM
As you know, brake fluid is hydrophilic or hygroscopic or some other two-dollar word. Means it loves water. Water then gets into the calipers, and it is difficult or impossible to effectively flush it out of the calipers. Pushing the pistons all the way into the caliper bodies, and bleeding with them in this position does the best job of evacuating old fluid and water, but the best way and the only way to truly replace all the fluid is to remove the pistons and flush them out with brake cleaner. When you do this, you are likely to find some rusty gunk on the pistons. Pistons can be replaced of course, and usually they just need a good wiping down. folks sometimes think that bleeding brakes renews the fluid and this is 90% true but not 100% true. And when it comes to brake systems, water is not your friend. Warren recommends rebuilding calipers annually or biannually. If this is done, your brake calipers are always in good shape and they should last forever.
ianc 05-17-2005 10:27 AM
Ha! Haha! :)
ianc
Superman 05-17-2005 10:57 AM
Ha! Haha! :)
ianc
Laughter may indicate an opinion that this level of maintenance is overkill. And yes, annual caliper rebuilds are uncommon in the general population. But I think Warren may have some aluminum calipers which are fairly difficult to source and vulnerable to corrosion. And if the laughers raced the maintainers to Peru and back, the maintainers would win by not having a spec of mechanical trouble. I probably rebuild my calipers every 2-4 years, and I find rust. Also, when you rebuild calipers from time to time, it becomes a very easy task. I could probably rebuild my rear calipers in an hour easy, start to finish, taking my time. It's a zen thing.
island911 05-17-2005 11:26 AM
Originally posted by Superman
As you know, brake fluid is hydrophilic or hygroscopic . . .. Water then gets into the calipers, and it is difficult or impossible to effectively flush it out of the calipers.
. . . folks sometimes think that bleeding brakes renews the fluid and this is 90% true but not 100% true. .. .
Thanks for the explaination; though I think that your mental-model of what's happening is off a bit.
brake fluid is hydrophilic . ..that does NOT mean that it some how collects water, carries it to the calipers, and then leaves it there . .. like a puddle. .. .somehow tough to flush. NOT AT ALL.
Just flush the system with new brake fluid. The hydrophilic nature of the new ("dry") fliud will act like a dry sponge to any remaining "moist" brake fluid.
Thing is, your not ever going to keep all the moisture out of the system. All you can do is be reasonable about it. (change the fluid)
Else, I suppose you could rebuild them only in Arizona .. .and be certain not to breathe on them during the rebuild (you've seen what happens when you breathe on a mirror; haven't you?) :eek: :rolleyes:
jazzbass 05-17-2005 11:36 AM
Re: Re: When to rebuild calipers?
My thoughts exactly. Brake system re-do should be the first order of maintenence for anyone buying a 15+ year old car.
Nine9six 05-17-2005 12:32 PM
If you don't know when they were rebuilt last, then it's time. A kit costs just a few bucks...
Superman,
I respect your opinion, but on this point I disagree.
Lots of folks do not know, if or when their calipers were ever rebuilt. Are you saying "its time" just because you do not know?!
Rebuild kits for my Turbo Look car are $70 per caliper from our sponsor. Apparently, you are in a much higher tax bracket than I
If your car exhibits any of the traits of dragging rotors, and you can confirm, then "its time"
Nine9six 05-17-2005 12:41 PM
Please note that doing this may cause more problems than it solves. Pistons have a "normal" range of motion, when mounted and performing their normal job. To push a piston back beyond this "normal" range of motion, you run the risk of forcing any contaminants/crud/rust, that may be stuck on the piston, past the sealing o-rings, and thus risk damaging their sealing properties...
Superman 05-17-2005 12:44 PM
Nine9six, it's not possible to disagree with me and still be correct. (Winking face goes here). Even at $70 per, if the vehicle were 15+ years old I would rebuild its calipers. And the probability that my tax bracket is above yours can be characterized as "remote."
There are several things I have noticed that mechanics tend to do fairly quickly to older, used cars they buy. Shift bushings, for example. New clutch cable is not a bad idea. Tranny fluid change. Caliper rebuild.
vash 05-17-2005 12:44 PM
when i bought my SC. i was thinking along the lines with supe. i was about to order rebuild kits, when i talked to the PO. (we are friends). turned out that he installed new rear calipers and had the fronts rebuilt. saved me a few bucks and some time. but i would have done it for "clean slate" piece of mind. job is easy enough. i even have a dedicated bike pump for the job.
every caliper i have popped apart, has had (some) sediment in them. what is that stuff? sand?. flushing gets that out too?
Superman 05-17-2005 12:46 PM
Hah! gotcha. This is true, where the parts have not been disassembled, cleaned, lubed and rebuilt. It's especially true of master cylinders. But where the MC and/or the calipers are maintained properly, this will not be an issue.
randywebb 05-17-2005 01:02 PM
OK, which calipers need to be rebuilt how often?
S type with Al pistons? vs. others w/o the corroding Al pistons??
If you guys reach an informed consensus, or even different but defined positions, add it to the long term maint. thread...
And where is Dr. Brakeburg on all this?
304065 05-17-2005 02:02 PM
Hey BD
Rebuild them when they look like this: (caused by Watkins Glen)
http://forums.pelicanparts.com/uploa...1113182118.jpg
B D 05-17-2005 02:23 PM
I am rebuilding them just having a little trouble sourcing the rear caliper rebuild kits as you may have seen in my other thread.
http://forums.pelicanparts.com/porsche-911-technical-forum/221885-1968-911l-911s-rear-caliper-kits-nla.html
KCPSG 05-17-2005 02:48 PM
well I somewhat agree w/superman..however I think that rebuilding you calipers every year is quite excessive, I did decide to do the caliper rebuild just about 6 weeks ago when I was installing new rotors and pads and lines...it was just a little more to go on and do the rebuild too.
And now I have piece of mind since I didn't have any paperwork showing when or if it had been done before. I might have thouhgt twice about it if they were turbo rebuild kits. (more pricey) but I think I still would do it, it just gives you a good base line to start w/. The job is probably a 1 on a scale of 1 - 10...it really is not that difficult if you are even just the slightest bit mechanically inclined.
otherwise another tell tale sign for a rebuild is ...are the leaking???
or not releasing.?
