MYSTERY~!! What's with the fueling?
1980 911SC
EVERY-TIME I try to fuel this beast, at ANY fuel pump - whether the newest best state-of-the-art pump or any old pump, the same results: Completely intermittent to barely able to squeeze the pump trigger before the trigger 'falls thru'. Various techniques with very little success: fueling nozzle all the way in and partially in; barely squeezing the trigger and carefully squeezing the trigger. Anything more than barely will ALWAYS result in trigger fall thru and pumping being stopped. It's taking me 30 minutes to fill the tank!! (I've only had this beast long enough to go thru 3 tanks...). Fuel Tank and/or fueling neck not grounded? Or What???? Any experience with this? Jim |
Try the search button but I think alot of guys turn the pump handle upside down. I, on the other hand, have never encountered a problem refueling. I just insert the nozzle leaving it about half way out. Hope this helps out.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Friend of Warren
I do the same as Wayne, only put the nozzle about half way in.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Nozzle half way in, boot not sealed around filler neck.
Matt West 1980 911 SC |
Half way in...nope - no sucess with that either...
So, any engineer types want to hazard a physical reason for this manifestation? Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
Try only placing the tip of the nozzle in the neck of the gas filler neck--just barely enough not to spill gas, then modulate the gas flow starting at just a trickle and see how much she can take. Mine gave me fits but now fills easily for some reason.
1980 911SC Targa 3.6L |
The Unsettler
Think of the design.
Basically the filler tube bends away from you, the bend is opposite of what it is in most cars. I flip the hose around and have no issues.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
