kcf7z's Avatar
What oil line is this?
I dropped my motor for a clutch change and found this hose was leaking. it looks like it has been repaird with a hose clamp in the past. When looking through the pelican site and other sources, I am having difficulty determining which line this is. It probably is obvious but as I am ordering a pressure plate bolt that we broke in replacing the clutch, I figured I would order this at the same time.
Old 05-17-2005, 05:35 AM
kcf7z's Avatar
By the way this is out of a 79 Euro 930
Old 05-17-2005, 05:41 AM
Bird. It's the word...
Fishcop's Avatar
It looks like a sportomatic oil line... but obviously not if it's a turbo
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-17-2005, 05:51 AM
kcf7z's Avatar
bump
Old 05-17-2005, 07:50 AM
Jubbie's Avatar
Thoes valve covers don't look turbo either. What is the engine number?
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 05-17-2005, 09:35 AM
kcf7z's Avatar
I think the valve covers were changed out by the previous owner. It is definitely a 3.3 liter turbo engine. I am not sure why the valve covers were done as such - my guess is as a cheap replacement for those that leaked. I don't have the engine number in front of me but it starts with 930.........
Old 05-17-2005, 09:45 AM
chrisp's Avatar
What did the open end connect to?
I don't know much about Turbo motors but on my 3.0 the only oil lines that are that diameter are breather hoses and they are in that general vicinity...but don't have a flare/nut fitting or any hard sections.. All of my lines that carry oil in or out are significantly larger in diameter.
'83 SC
Old 05-17-2005, 09:52 AM
kcf7z's Avatar
I think it connects the oil tank to the oil pump for the turbo. the hardline on the engine traverses the front of the engine
Old 05-17-2005, 10:11 AM
