XLR8'd Member
Sunroof lift during closing
Rebuilt sunroof including cables, slides well but now front won't lift for proper closing. Adjusted the height screws and still no go. Any suggestions it seems to get snagged on the deflector.....
Thanks Dave 84 911 Blk Acura Integra 96 Outback 2001 Honda Mini Trail 50 1976 |
UFLYICU
Sounds like the little black clips under the deflector might be broken. (Yellow arrow)
They keep the deflector aligned so it drops flush when the sunroof slides forward. I think you can get them from PerformanceParts.com ![]() You might also check the springs on the hinges. If they break, the deflector won't stay up when the sunroof is open, which creates the two little "ramps" on the sides for the sunroof to ride up when closing.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 05-17-2005 at 10:58 AM.. |
UFLYICU
Here's a better pic.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
XLR8'd Member
ya....might be exactly that, one of the clips holding the deflector is rocken.....Being in Canada it will probably cost me $30 to ship that $2 clip!
![]() Thanks! Dave "Go to HEAVEN, Drive Like HELL!" |
XLR8'd Member
Zoanas,
Any chance you have the prosche part number for that clip for the roof deflector (right side)? If not, do you know any tricks where I can find official part numbers. Dealers are clueless when it comes to old Porsches in Montreal. Cheers ! David |
UFLYICU
Part number 909756 available at ************************. It's called a "Sunroof Air Deflector Clip".
$3.95 ea The rest of the parts can be found on page 229 of the current issue of PP
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 05-17-2005 at 02:37 PM.. |
