-   -   Which Sunroof Seal Do I Need to Replace (http://forums.pelicanparts.com/porsche-911-technical-forum/222064-sunroof-seal-do-i-need-replace.html)
bento 05-18-2005 12:14 PM
I recently used my new random orbital polisher on my sunroof coupe and it appears that I accidentally caught the seal on the back edge of the sunroof (closest to the rear window). I have attached a crap cameraphone picture for reference, please excuse the quality. The question is: Which seal do I need to replace? Will I have to pull the sunroof panel out? I have read a few threads on this topic and there is conflicting advice on this issue.
Davidhttp://forums.pelicanparts.com/uploa...1116443712.jpg
RickM 05-18-2005 12:25 PM
Edit previous post.
Here: http://forums.pelicanparts.com/showthread.php?s=&threadid=191467&highlight=sunroo f+and+seal+and+two
PP Part #s C-564-191-00 front and C-564-193-00 rear (attached to panel)
http://forums.pelicanparts.com/uploa...1100028097.jpg
http://forums.pelicanparts.com/uploa...1100028108.jpg
bento 05-18-2005 12:34 PM
So the appropriate seal is on the sunroof panel itself?
I read the attached thread, thanks btw, and it appears that it is. Do I have to remove the sunroof panel to replace it?
This is the correct seal, no?
http://www.pelicanparts.com/catalog/...of/8-11-50.jpg
Pelican Parts Item # C-564-193-00
Thanks for such a prompt response.
david
RickM 05-18-2005 12:38 PM
Yes, attached to the panle with that part #.
I can't recall if I removed the panel or not. I'm not thinking so.
bento 05-18-2005 02:21 PM
Talked with my mechanic at CT automotive and he suggested that I suggest both the front and back seals as well as the two front hinge pieces and the deflector plate. He said that these items apart from the seals were pretty cheap (a buck for one and a couple of bucks for the other). Thoughts?
db
