autobonrun's Avatar
Porsche Crest Crushed Evap Coil and busted plastic in 79SC
My A/C blower quit today after making a rubbing noise for several days. I thought the motor was shot but when I removed it, it tested ok. Evidently a piece of the broken plastic froze the fan in place. Several pieces fell out when I removed it. I'm sure the busted plastic is what let the fan shift out of alignment.
Here are my questions. The motor is fully set in place but the bottom crushes the evaporator. Seems like it's been like this for some time. Is this normal or is the evap set too high? How do I lower it? Should I look at replacing the evaporator that's just crushed in the center or should it be ok as is? I'm concerned the crushed fins could cause a loss in an already inefficient system.
The plastic housing that the motor sits in is cracked. It is a separate piece from the cover and is sealed in place and held there by a bolt or two. Can I just buy the plastic motor support without purchasing the entire motor assembly? I'll try glueing it if I have to but I'd rather buy a new piece since this plastic is 26 years old and must be brittle by now.
Here are some photos of the setup.
Old 05-17-2005, 07:40 PM
Send a message via AIM to fintstone
Pretty sure our host has the plastic part you need:
OEM-91157332300 $49.62......At that price, perhaps you should just try to epoxy it.
Maybe it is just my old eyes, but from your picture, that does not really look like the right motor. Perhaps it has been replaced. Is there a part number on it?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-17-2005, 09:08 PM
autobonrun's Avatar
Porsche Crest
Thanks Fintstone for the info. I had not considered the possibility of the wrong motor. I'm only the second owner of the car and have had it since 1984 and don't recall replacing it. However, I keep all my maintenance records on computer and will check tomorrow. I tend to think the motor is correct since the four metal clips that hold it in place fit perfectly, however, I'll look for a part number once I remove it from the frame.
I'll try the epoxy first as you suggest then if that doesn't work, I'll bite the bullet and order the part. Gorilla glue might work; the stuff is pretty strong. I'm thinking I might as well have the motor partially rebuilt while I have it out. I'll play it by ear for the moment. I'll also see if I can straighten out some of the evap fins.
This shot shows the clips and the fact that the frame has split all the way through.
Old 05-17-2005, 09:22 PM
91162489900
It looks right, but somehow seems to stick out too far. I cannot tell from the pix, perhaps you can.
Old 05-17-2005, 09:50 PM
bigchillcar's Avatar
interesting..your evaporator looks nothing like the one in my '74..in fact, mine looks a whole lot newer? i'm not able to see fins as mine is in a black plastic housing. it has a brand name label in view that i'll have to go check out tomorrow. good luck with the repair.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-17-2005, 11:36 PM
I just pulled the evaporator out of my car, and you could have it for the cost of shipping. Let me look at it when I get home. I think I broke one of the clips for the fan housing when I removed it.
If you want it, its yours.
Rod
1980 SC Targa
Old 05-18-2005, 05:06 AM
autobonrun's Avatar
Thanks for the offer. Let me know what it looks like when you get home. I'll send you PM.
Thanks again.
Old 05-18-2005, 05:35 AM
big chill...you can cee the evap fins because he has removed the cover (top) of the box.
Old 05-18-2005, 11:24 PM
dohhhhhh! that's what i get for posting late after a wee much gin..
ryan
Old 05-18-2005, 11:37 PM
