911 carrera 3.2 (1985)
Can someone tell me how to replace the fresh air blower motor?
911 carrera coupe 1985 (euro). Thanks, Kees. |
If you haven't purchased the Bentley Manual I would highly recommend it if your going to be doing your own repairs.
As for the blower. you have to remove the panel at the rear of the front trunk and the fresh air intake grille on top. Disconnect the power connector then the hoses including the plastic "Y" connector under the blower housing. Also disconnect the control cables. If you mark the control cable connector locations with a marker it helps with reinstall. Unbolt the housing, bolts are in the trunk and accessed through the intake with grille removed. There is a brace that I unbolted at the top and moved also. The blower housing should come out with some wiggling. There are some clips on the housing that snap off, inside is the fan/motor assembly. I would recommend buying the motor with fan. It is very difficult to remove the old fan witout damage, plus they are balanced at the factory. That's the short lesson, I am sure I forgot a few details but that should get you there. Good Luck Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Andrew, thank you very much.
Kees. |
