I'm not here.
K. Roman's Avatar
largest fuch rims for 1965
What's the widest rim that'll fit without changing the fenders?
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 08-02-2005, 04:35 PM
PRO Motorsports
Tyson Schmidt's Avatar
6's without a doubt, and 7's with a little finesse.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-02-2005, 05:56 PM
JCF JCF is offline
I'm pretty sure the widest is the 7 R. Has enough offset. Otherwise 6's with 195's
John
Du must schwein haben
'67 901/05 rebuilt 2.2
Bultaco Metralla 62 "XDina"
'68 BMW R69S
Old 08-02-2005, 05:57 PM
I'm not here.
K. Roman's Avatar
thanks...I may add some fenders then. can a SWB accept a front RS bumper and SC rear fenders?
Old 08-03-2005, 12:33 AM
3 restos WIP = psycho
kenikh's Avatar
You can have custom fuchs made from deep 6s that will result in a 7R offset, but come to a little wider than 7.25". I have heard Harvey Weidman will make them for you. Apparently this will allow mounting of 225 rubber under the rear of a narrow, unrolled lip car with about 2 degrees of negative camber.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-03-2005, 08:00 AM
Even if you could...please don't do this. The early body style is stunning... Have some 6's widened to 7's, and then you can run 225's. I am, with no clearance issues, and that's plenty enough rubber for the road...I've got a 2.7 twinplugged dyno'd to 240. I think the "sleeper" look is perfect for these older cars.
regards,
Eric
67S
http://www.autoforeignservices.com/
57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc.
Old 08-03-2005, 09:50 AM
kenikh's Avatar
Roman, I'm with Eric on this one. My car had RS flares added to it by a PO. It looks sharp, but there is a part of me that wishes I were hiding that rubber underneath flat fenders. The cost of adding flares (welding, paint, etc.) isn't going to be cheaper than widening the wheels, so SERIOUSLY consider going this route versus permanently modifying another narrow bodied beauty. You'll get all of the performance, plus the 'wow' factor of some seriously cool and unusual wheels.
Eric, I can't wait to see the "secret" wheels you just had built by Harvey.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-03-2005, 10:13 AM
I'm not here.
K. Roman's Avatar
Thanks for the info. I just want to have enough rear tire on the road to be able to handle the 3.0. It's carbed right now with one zenith and one weber. (ask the PO) I'd like to do PMO's and am going to have some Lexan windows, so the little thing is going to be quick.
I really want to do a 67 911R replica but wanted to add a front oil cooler also, so was thinking about the '73 RS bumper.
Old 08-03-2005, 10:40 AM
kenikh's Avatar
You could get more than adequate oil cooling with front fender mounted oil coolers at both corners, thus maintaining the clean look of the SWB. The 3.2 cars did this with great success. There are always ways around doing something you might not like later.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-03-2005, 10:45 AM
I just added a front cooler, used Elephant racing lines (painted barbeque black!), looks very "purposeful" on the car, and cooled the engine down significantly. Mounted the cooler up in the passenger front fender.
Eric
Old 08-03-2005, 12:34 PM
you could also run twin coolers behind the horn grilles. Mercedes transmission coolers work well.
HTH
best
jerry
Old 08-03-2005, 12:40 PM
