-   -   replacing cam feed line, RHS. (http://forums.pelicanparts.com/porsche-911-technical-forum/222366-replacing-cam-feed-line-rhs.html)
RG5 05-20-2005 05:22 AM
I have ordered a 3.2 Carrera RH cam feed line. It this something that is relatively easy to replace? Is it just a matter of unbolting the old one and swapping over. Will the line be under pressure with the engine cold?
Any helpful hints welcome
AFJuvat 05-20-2005 05:25 AM
You will get some oil running out of the fittings when you remove it, but no serious pressure will be inthe lines.
You will have to remove the AC compressor to make access a lot easier.
AFJuvat
RG5 05-20-2005 05:30 AM
No AC on my car so it should be OK.
Any other issues to watch out for?
kqw 05-20-2005 06:46 AM
On the banjo fitting (next to the valve cover) you have washers. Don't loose them.
