Strange rattle coming from fan area
I know this is vague and a long shot but I've got a strange rattle that has gotten louder over the past week coming from what seems to be inside the fan shroud. Anyone experience this? How should I go about trouble shooting this?
1980 911SC Targa 3.6L
Old 06-02-2005, 05:46 PM
Registered abUser
TerryH's Avatar
Alternator?
Alternator noise revisited
'81 911SC Coupe SOLD
Old 06-02-2005, 05:51 PM
bigchillcar's Avatar
hope it isn't cam chains..try placing something like a screwdriver against the cam covers and listen to eliminate them. otherwise, perhaps a bearing going bad in the alternator..disconnect the fan belt and run the engine BRIEFLY to see if the noise stops or continues.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-02-2005, 07:43 PM
Thanks--I'll try that Ryan
Old 06-03-2005, 08:56 AM
jon,
just realized that you have a 3.6 (you lucky )..hopefully others will chime in who have 3.6 experience, although i think the aforementioned test would still be applicable for you. good luck.
ryan
Old 06-03-2005, 10:10 AM
gduke's Avatar
On 3.6L there is a fan belt sensor. It's basically a roller that presses against the fan belt. It could be lose or worn out.
1985 911 Carerra Cab 3.6l
1998 Dodge Ram
2004 Toyota Tundra Quad Cab
Old 06-03-2005, 04:37 PM
Air Medal or two
afterburn 549's Avatar
"some " brands of oil filters make a chain like noise too
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 06-03-2005, 07:59 PM
Licensed User
Shuie's Avatar
Thats kinda what a failing chain tensioner sounds like. But you have a 3.6, so it cant be that
Old 06-03-2005, 08:03 PM
