Stranger on the Internet
Turbos and Carbs
Anyone running a turbocharger with carbs out there? I'm just curious about the details.
Pat
Patrick E. Keefe 78 SC |
you got my view
SWB |
Its a pretty bad combination.
Senior Member
I've never heard of such a thing.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Before there was really expensive and sometimes unreliable fuel injection, there were carbs. Back in the stone age! We had turbochargers back then.
Crusty Conservative
Corvair Monza Turbo, Olds F-85 turbo, Maserati BiTurbo, a few British POS's as well.
You have two choices when you combine carbs and a turbo: 1. Pressurized carburetor containment chamber 2. Compressing air/fuel mixture Both have been done, neither one works very well for a number of reasons...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
I've actually had draw throughs work fairly well. I'm contemplating upgrading to a low boost turbo for the SC, so my options are carbs or CIS. Other options discounted because I'm cheap.
Pat
Blow through's and draw through's are quite popular with VW type I and type IV... they stick one SU or IDA carb at right off the manifold for draw through, or use duals with a pressurized air cooler housing. 300hp for under 5K is not uncommon.
http://www.cbperformance.com/catalog.asp?ProductID=285 http://www.et-studios.com/motorsports/motorspy/predelivery.html
David Avery 05 Lotus Elise (sold) | 08 BMW 135i visit FocusedE, my e-business company | visit Spyderclub |
Crusty Conservative
Well all 911 turbos prior to the 964 were CIS injected, that ought to tell you something...;-)
Crusty Conservative
What you say may be correct, but both of your references are to fuel injected VW engines - looks like some carb bodies converted to butterflies, with injectors below...
With cost effective EFI solutions out there fabbing up a turbo system with anything less makes no sense.
Still Doin Time
Turbos and carbs go together like tequila and pepto
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
OK. I'm throwing in the carburetor towel. I have seen the error of my stone age ways.
Pat
Crusty Conservative
I believe there is somone on this board who restored an older aftermarket turbo system for the CIS engine, and has it running on his car.. maybe someone recalls who that was.
BTW Pat, don't go by my views on this subject - I am not a big fan of turbos on street gasoline engines period! But that's another subject.
Former Options Trader !!!
Yea that Maserati biturbo with the carbs was a real treat. maybe 11 days a year it ran correctly.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
Well, if someone wants to take the factory CIS route I still have some of my old 930 CIS stuff for sale.
Unregistered
I have sucessfully built a tuirbocharged porsche with a carb, but it was a 914 with a 4 cylinder. if I had to do it over again i would install CIS on it. Does that tell you anything?
MAJOR PITA dialing in a carb with a turbocharger. CIS does it for you, up to a point. |
Yeah, I'm thinking that the CIS route will likely be the way to go. I don't have to reinvent the wheel that way
![]() Here ya go: http://www.shoptalkforums.com/viewtopic.php?t=85128 http://www.pbase.com/550joe/jason
Those look like blow throughs to IDF Webers, pretty common on the type I engines. Some you see are draw throughs with DCOE Webers. It's the extra two cylinders that present a plumbing problem. Those Webers are pretty tolerant to turbos on mid to high boost once they're jetted correctly.
