Cool Collar Install
How do install this thing with all the A/C hoses in the way?
![]() Previous threads suggested removing the bolts from the compressor and moving it out the of the way or to cut the cool collar in half. Anyone had any luck with either of these approches? Could I also ask my wrench the next time I do an oil change to slip it on before oil filter install? Would I have to shorten the collar first? Thanks for the help. Kato.
Montana 911
remove the oil filter and install cool collar....put oil filter back with the collar already mounted. The AC hoses should be able to be pushed to the side enough for this. If not....pull the entire AC assembly and shave a few pounds. =o)
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
I cut the cool collar in half for easy on easy off.
"Igneous Aquam et Laudi semper" Carl Muckley |
My compliments to you gentlemen. A Cool Collar thread without a single nasty, I-heard-they-suck, knee-jerk, moronic Cool Collar put-down. The CC in my 911 is the same one that was in my airplane. All three of us--me, airplane and Porschie--have survived.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
If I can cut down 10-20F that's good. If it does nothin' and I get the "what the hell is that thing question" it's worth putting it on. And having some beers discussing why or why it doesn't work afterwards... |
Thanks. |
If this is what you did was one clamp sufficient to ensure full surface area contact? |
Unregistered
How many degrees?
Stranger on the Internet
For all of you guys who have fin tube baseboard heat in your house...it is a 3/4" copper pipe with a cool collar on it. Any questions on their effectiveness?
Kato-push the A/C over to the left a bit, and you should be ok. This is what I have to do when I run out of mann filters and have to use the local store bought models, which are a bit longer.
Patrick E. Keefe 78 SC |
I think I may get one just so I can polish it...Looks much better than the standard oil filter
![]() Eric |
Mine has a fan blowing across it. (under the intercooler).
are you guys seriously still buying the cool collar?? (ducks)
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
this thread has officially lost its cherry
![]() ryan
Is there any published data regarding the heat transfer effectiveness of a cool collar, besides unfounded clains by manufacturers and out opinions on whetehr they work? I personally have never seen any.
Pat
Banned but not out, yet..
The cool collar is extemely effective in generating countless threads .
An air cooled refrigerator. ‘Mein Teil’ |
Warren Hall Student
"The cool collar is extemely effective in generating countless threads"
LMAO!!
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I can't tell from the pics what brand of AC compressor you have but on my 83SC with a Sanden I rotated the compressor so the hoses were on top rather than towards the oil filter it freed up a lot of space to make oil filter removal much easier.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
It must do something, maybe 0.1F - 20F if you read the claims of others. Bottom line it's a heat sink and will remove some amount of thermal energy from the oil. It's just too bad it can't be made thicker with fins about 6" long. Of course if I decided to change out my oil lines with those finned ones I'd be set. That's a heck of alot of surface area for a heat sink! Let it rain .... |
FSW, is that the STC'd version?
(inside aviation joke)
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
