Install425's Avatar
A/C oil
How much oil should I add to a new a/c system. New compressor , front Condensor , New underbelly Condensor , New rec / dryer , Evaporator , New hoses. I have heard that oil has to be added for every component in the system. I have also heard that you should not mix mineral oil with Ester oil. I am using R134, My compressor came with mineral oil in it already. Thanks
Rob,
88 911 Turbo
Old 05-23-2005, 09:35 PM
rfuerst911sc's Avatar
Drain the compressor of the old oil. I did basically the same setup as you and I added 8 ounces total, I put 2 in the compressor,2 in the receiver drier and then an ounce in a few of the hoses this way the compressor doesn't have to move a huge slug of oil when you first turn it on.
Old 05-24-2005, 03:15 AM
Install425's Avatar
Thanks rfuerst, that is what I thought. I just don't want to add to little oil at this piont and have in break.
Rob,
88 911 Turbo
Old 05-24-2005, 03:34 AM
da911enginear's Avatar
from what I have read, Ester does mix with R12 ac mineral oil, it is the early versions of PAG that do not mix with the old R12 oil
Old 05-24-2005, 04:23 AM
