Bird. It's the word...
Rear Wheel Bearing Installation Question
I've just received my new rear bearings (great service by the way... 5 days to Australia).
The old ones appear to have possibly had some kind of bearing "locker" on the exterior surface, something like red locktite perhaps. My question is... should I use a locking compound also, or is the interference fit (bearings are in the freezer) sufficient? What have you guys done? Cheers
John Forcier Current: 68L 2.0 Hotrod - build underway |
Re: Rear Wheel Bearing Installation Question
I guess they are SKF? I wonder what SKF would say?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I guess that's a thought Ron. Wrong time of night here to call though
![]() Yep, they are SKF. I can't say that the ones I've removed are the originals, but they are FAG and have a depression around the circumference that seemed to have a red coloured "sealant" that was not elastic in nature...
I have part of the old inner race out of one of my rear wheel bearings on my desk here at work - it's an SKF bearing.
Anyway, this fit is an interference fit - not locking "sealant" is required. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Thanks Mike
But it appears I'll have to do something... I just did a test fit, and I can insert and remove the new bearing by hand at room temperature, there ain't no interference ![]() From what I've found in searches, the SKF bearings are fractionally smaller than the FAG equivalent.
Hmmm...interesting. I froze my bearing and it still needed some persuasion to install. My application was a '76, but I thought '69 and later used the same rear wheel bearing configuration. Maybe it's the steel trailing arm?
Sorry I'm not much more help... Mike
Anyone else??
