Kelly Bell's Avatar
Oil in Exhaust?
My 75 911s sat for 4 years before I bought it. I am going thru it slowly. I can make it run for a moment by putting gasoline down the throttle bodies, so I at least know its compressing, ect. I think there must be some FI problems, which I can fix. Heres my question:
I was putting new gaskets in the heat exchanger, and having it bead blasted and I notice a buch of oil was in the header and collector (no thermal reactor, the PO took it off?). I have heard this is normal with boxter engines, as oil pools arounf the cylinders/valve trains.
Has anyone ever had this happen?
Thanks!
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 05-24-2005, 04:45 PM
Kelly Bell's Avatar
Bump.
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 05-24-2005, 06:32 PM
Let's get this started for you. Oil will drain back into the case over time.
It can leak into the cylinders, many Porsches will give a hello puff of oil smoke at startup. If the car sat for a long time, I guess the oil could make it's way into a cylinder and out a open valve.
David 89 turbo cab
Old 05-24-2005, 07:03 PM
Kelly Bell's Avatar
Thanks, David. I love tht picture to the left!
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 05-25-2005, 02:36 AM
