-   -   Please Help, Ignition/Coil problem. (http://forums.pelicanparts.com/porsche-911-technical-forum/223222-please-help-ignition-coil-problem.html)
Manipou 05-25-2005 09:55 AM
Does anyone have a wiring diagram of the wiring from the electric control unit to the coil and all other wires. I have wired it all up but can not get power to the coil and therefore no spark. I may have wired it up wrong... Please any help will be great. Thanks
Early_S_Man 05-25-2005 10:20 AM
It would help if you posted what year car and model 911 you have ... and the year of the engine, if different.
buster73 05-25-2005 10:52 AM
If you have an early car attached diagram should help with the CDS wiring. http://forums.pelicanparts.com/uploa...1117043537.jpg
Manipou 05-25-2005 11:55 AM
Yes sorry, it is a 1972 2.4E. Does this diagram match the car? Thanks
BK911 05-25-2005 12:05 PM
Yup, that should get you started. Others are located here:
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
Use the ones from a 71.
