Ligtening the SC, remove undercoating?
I was thi9nking fo ways to lighten up the SC a bit, and it occured to me that the undercoating i had to remove to mount the Carrera cooler was REALLY thick..
There's got to be quite a few pounds of this stuff all over the car, any one have any suggestions for stripping all this stuff off? Is it actually worth doing? |
what state is Room 101 located in?
do you drive on the street? do you enjoy tons of mindless drudgery? |
In all there is about 40lbs of undercoating sealer stuff on the car.
I stripped mine to bare metal, and collected all the goo in a box and weighed it when I was done.. It is alot of work though |
I'm taking mine out a little at a time.:rolleyes:
When I put new carpet in, some came out. When I put my roll bar in, more came out. I've never been excited about stripping it all, as there are many posts here about what a job it turns out to be. |
2. Yes I drive on the street 3. Sometimes... |
I wouldn't bother on a street car unless you are going to go all out with the lightening campaign and remove say 250 lbs.
It's a piece of cake. I was wasting time with a heat gun and scraper. Got tired of that Sh_T and started looking around the internet for a better way. Found this web site: http://www.svend.net/mustang/ww73/ww73.html
I took a chance and bought the Peel away 7. Oh-my-God, that stuff is amazing. Simply put it on wait 24hrs and the undercoating comes off like butter. Well a small amount of elbo grease, but not much. Finish off with a cordless drill and wire brush then Por 15. Boom, your done. Fumes not very bad at all either. Toughest part is painting the Por 15 on upside down. Good luck |
salt is the imp. thing re your location
you are removing wt. from the least harmful place on the car... Do the stuff advised on your Rennlist post first... |
lol...you gotta admit the extremes we come up with can be pretty funny, jared.. ;) even funnier is the fact that apparently as another has posted, you CAN actually lose, like 40 lbs.! i'm trippin'...
ryan |
I'd rather remove useless interior bits - like seats - if you haven't already done so, Jared.
Jared:
My SC weighs 2600 lb. If I spent the necessary time on my back with harsh chemicals, a scraper and wire brushes, and lots of clean up time, I could probably get down to ....2560 lb. Good luck Pat |
| All times are GMT -8. The time now is 07:49 AM. |
