Wobble,wobble
I drive a '77 911 3.0 and have 16" Remotec offset wheels on the front end. I continually get wheel wobble @ 60-65MPH. Have had the wheels balanced to perfection. Is this a geometry thing? Is the offset causing a balance problem? Thanks.
Old 05-20-2005, 10:11 AM
I wobble like that usually means a bent wheel.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 05-20-2005, 10:37 AM
Worn tie rod ends, worn/loose bearings? Tough to say without more information. Is there any play when you rock the wheels with your hands in the 12 and 6 oclock position?
Old 05-20-2005, 10:41 AM
MAS MAS is offline
With my 77, it was the (front) tires. I replaced all 4, and the problem vanished.
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 05-20-2005, 10:58 AM
Have the same problem at 60 mph with my targa, I checked the balance 2 times and this woble seems to be worse my targa top is off. don't ask me why, I have no clue
The only thing I can think is that one my (new) tires is defective. I will have to find someone to swap tires with and see what happen.
87 Targa
lexus RX300
Ford Expedition
84 Alfa Sprint Veloce (sold)
89 Renault 19 16 s (sold)
Old 05-20-2005, 11:35 AM
Banned
I replaced my tie rods with turbos and it made a dramatic difference. I had the same wobble at freeway speeds.
Old 05-20-2005, 12:04 PM
bigchillcar's Avatar
if able, do a simple front to rear rotation and check..negative front camber wore my front's more on the inside giving me vibration at speed..rotating cured it. that was my problem - i'd negelected a 6 month roatation..won't again..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-20-2005, 12:19 PM
Meaning you had them spun on the car?
Joe
Old 05-23-2005, 10:43 AM
Re "wooble"
*Checking tie rods
*Wheel balance on car good idea due to possible uncentered hub extensions.
Old 05-26-2005, 01:57 PM
