-   -   How To Reduce Height Of 3.2L Motor? (http://forums.pelicanparts.com/porsche-911-technical-forum/223321-how-reduce-height-3-2l-motor.html)
jyl 05-25-2005 08:54 PM
I have a weird question.
Suppose you had a 3.2L motor and wanted to reduce the height of the motor (measured from crankshaft to the top of the AFM unit) by about 6 inches.
Could you simply shorten the intake manifold runners, by cutting out a section and then welding the runners back together?
Would the reduced height mess up any other components? How would the shorter runners affect the motor's performance?
Porschekid962 05-25-2005 08:56 PM
plastic intake...
jyl 05-25-2005 09:01 PM
You mean from a 3.6L? Would it fit and wouldn't you be messing with Varioram and so on?
Suppose you also need to pass California smog. Would a smog center pass a 3.2L with a plastic manifold?
island911 05-25-2005 09:13 PM
Tonys EFI kit seems to take a lot of height out. IIRC
widebody911 05-25-2005 09:21 PM
Us a non-Vram plastic intake?
What are you trying to do, fit this in a bus?
strokher racing 05-25-2005 09:40 PM
6 inches is a lot to cut out of that intake! Just a bit of info for you longer runners tend to make more torque and shorter runners tend to have more top end hp. The plastic 964 intake is not much shorter if any compared to the 3.2...I will have to measure. You would have to get adapter plates made or go with an injector block like mine to adapt the bolt pattern.http://forums.pelicanparts.com/uploa...1117082384.jpg
Eric Hood
obrut 05-25-2005 09:46 PM
how about side draft webers on angled manifolds?
don't laugh - a guy i know who likes webers (has quad downdrafts on his morgan plus 8) has just fitted quad side drafts to his 928 in a similar way and reckons they work great.
jluetjen 05-26-2005 03:44 AM
Did Weber make any side-draft 3-bbl's???
dickster 05-26-2005 04:40 AM
fitting Webers sounds agricultural to me nowadays:D
svandamme 05-26-2005 04:46 AM
the only ones i 've ever seen are 2 barrels
http://www.bccp.nl/images/030227tr6web1k.jpg
jyl 05-26-2005 05:41 AM
Well, I am shopping for a Vanagon . . .
svandamme 05-26-2005 06:00 AM
i say , raise the floor , see through , some neon lights, a little water fall, 22 inch gionvanni's and a 40" plasma
that would be the Shiznit.
anythizle ezle, wozzle bezle underachivizle.
or somethin
304065 05-26-2005 06:10 AM
Ok, Stijn, you win the award for the FUNNIEST comment of the month of May! Ha ha ha !
widebody911 05-26-2005 06:23 AM
This looks like a 2.7L or a 3.0L
http://volksweb.relitech.com/porsche6.htm
One concern with this engine conversion is the height of the Porsche engine versus the VW engine. To clear the taller Porsche engine, the engine hatch needs a raised portion added so that the engine cover can close. Luckily, the area that needs to be taller is all within the bounds of the engine hatch, so only the hatch itself needs to be modified, not the sheet metal of the van per se.
http://volksweb.relitech.com/wm_ken/engine.jpg
svandamme 05-26-2005 06:32 AM
i get one in every 1000 something posts right...
please bear with me for the other 999
jyl 05-26-2005 11:50 AM
Which seems like it would mess up the lower bunk.
kenikh 05-26-2005 11:57 AM
Yup; checkitout...
http://forums.pelicanparts.com/uploa...1117133823.jpg
ted 05-26-2005 02:11 PM
If it was a Diesel Vanagon with 3.2 would it need a smog test?
Saw this one for sale...
http://forums.pelicanparts.com/uploa...1117141864.jpg
widebody911 05-29-2005 08:47 PM
Check this one out:
http://home.arcor.de/becks/pics/pclaer.htm
http://www.becks24.de/claer_t3/claer_t3_ms_23.jpg
Shuie 05-29-2005 08:52 PM
The Subaru engine fits in there perfectly.
