Insert Tag Line HERE.....
rattlsnak's Avatar
fuel sending unit help.. (OHM range)
I just got off the phone with the Centriod folks about getting a fuel sending unit for my fuel cell, and they need to know the OHM range of the factory unit. Could be either 90-0, or 76-6, or 240-33 ohms, or a few others. The high number usually dictates a low fuel condition. They need to know if when you disconnect the unit does the gauge go to empty? And if someone knows or could measure the ohm output of theirs with it really close to empty, or full and let me know that would be great.
Thanks!
Old 05-26-2005, 12:43 PM
rattlsnak's Avatar
bump.....
Marc
Old 05-27-2005, 06:35 AM
rattlsnak's Avatar
Well, for those who want to know, its @ 72.5 empty, and @ 3.5 OHMS full.
Marc
Old 05-27-2005, 12:56 PM
CurtEgerer's Avatar
So is the 72.5 Ohm range consistent for all year fuel gauges? I'm having a problem in my 74 Carrera. 27 gallon Fuel Safe cell with Centroid sending unit. The dash gauge reads full when I fill the cell. But when the gauge gets down to about half, it suddenly drops to zero even though the cell is still half full. The sending unit is not marked with an Ohm rating. Thanks in advance for any help.
1983 AUDI Turbo Ur quattro
1987 PORSCHE 944 turbo
Old 04-06-2011, 10:15 AM
moneymanager's Avatar
There are variations in gauges but the unit is pretty linear so far as I know. Email Joel in support at Centroid. I found him very helpful in sorting out an issue I had...mine only indicated 7/8 full when filled. I'm living with it for the moment but it will go back to him for recalibration this summer.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 04-06-2011, 03:50 PM
rattlsnak's Avatar
post your results here to help others one day!
Old 04-06-2011, 09:17 PM
here is the link to Centroid's calibration pdf. Pretty straight forward. The problems I'm having so far, the sender does not appear to be linear. That is from a full tank to a half tank the gauge is really slow (reads too full) then from half to empty it plummets rapidly. Still fiddling with it. The adjustment screws are uber sensitive so be patient while you set it up. I saw a post on a ford forum where the guy put a dab of loctite on the screws, I may try that.
http://www.fuelsafe.com/pdf/Centroid-Non%20Programmable.pdf
Old 01-29-2013, 06:24 AM
I returned mine to Joel and they recalibrated. Had no luck with home fixes.
jhtaylor
santa barbara
Old 01-29-2013, 06:53 AM
was/is the issue resolved? I'm in the same boat does not read full, roughly 7/8ths to 15/16s and appears to be non-linear. The gauge is roughly ten years old though, I just started sorting the car and got to it.
Old 01-29-2013, 07:01 AM
Mine was new; that may have made a difference. Results were good. Full is now full. THese things aren't ever perfect but mine is pretty linear. One quarter tank in my cell should be 4+ gallons, in reality I have 5 or 6 so it's conservative.
jhtaylor
santa barbara
Old 01-29-2013, 07:17 AM
seafeye's Avatar
Kinda old thread. Does anybody know the resistance for a fuel sending unit for a 100L fuel tank?
What me speed?
Old 09-03-2017, 10:20 AM
seafeye's Avatar
Anything?
What me speed?
Old 09-14-2017, 07:06 AM
If the sending unit is made for the fuel gauge, the empty and full resistant specs should be the same as stated.
Sherwood
Old 09-14-2017, 04:19 PM
seafeye's Avatar
Ok thanks. I have a lovely 100l tank and would like to use my stock sender if possible. Maybe the 100L ones are slightly longer?
What me speed?
Old 09-14-2017, 10:44 PM
T77911S's Avatar
if you plan to use the original unit then I would measure from the mounting surface of the sender to the bottom of the tank for both tanks. if the 100l is taller then the gauge will show empty long before it really is.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-15-2017, 03:46 AM
Flojo's Avatar
sweet tank... they got real expensive by now.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-15-2017, 05:07 AM
Yes, you'll need a longer sending unit to measure the fuel level as it reaches the bottom of the larger capacity tank. Maybe someone can provide a contact number. I understand around $300 or so.
Sherwood
Old 09-15-2017, 11:41 AM
seafeye's Avatar
Thanks. I'll look into a longer one. Or I wonder if I can modify mine.....
What me speed?
Old 09-15-2017, 08:46 PM
