Ayo Irpin, Ukraine!
Hey, what could go wrong? Hell, vinyl would be a better but still a crap idea. Don’t want anything there that might trap moisture.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
hey nothing ventured, nothing gained. A lot of interesting details on your car, is there a thread on it anywhere?
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Ayo Irpin, Ukraine!
Yeah, there’s that, lol. Can you imagine the pull on that fabric with the lid down and the engine running? Probably why it already looks like a saggy diaper. That would do wonders getting sucked into the fan.
Bahama Yellow 912 Super 190. In the last 12 months the car got coil overs and Elephant's GT3 front suspension. 95% of the hot rod stuff is under the skin.
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com Last edited by cmpski; 01-25-2023 at 08:36 AM.. |
Kind of Blue
That's an amazing build. I love the fuel injected Polo motor. Any idea what kind of power it puts out?
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
The 912 Super and the Pelican community deserve a thread on this build.
Ass-engine Nazi slot car -- PJ O'Rourke |
Plenty of places to read about this car.
On these different sites the car is sneaking up on a million page views around the world. This is probably one of the most documented 912's in the world. This is the first 912 in the world to have this engine type installed 2010ish. Chris Pomares https://www.excellence-mag.com/issues/205/articles/less-is-more reSee works - Home A very cool article about Porsche almost putting a 4 cylinder 2CAM4 engine in the 912. The article is from the Netherlands. If you go to the back of the article you'll find an English translation. http://www.reseeworks.com/netherlands-article.html https://flatsixes.com/cars/for-sale-cars/polo-engined-912-911s-911/ https://www.912bbs.org/forum/threads/polo-4-cylinder-911-engine-and-1967-912-almost-done.37206/ https://www.early911sregistry.org/forums/showthread.php?69778-POLO-4-cylinder-911-engine-and-1967-912-almost-done https://forums.pelicanparts.com/porsche-912-technical-forum/624688-polo-powered-4-cylinder-911-motor-912-a.html https://forums.pelicanparts.com/porsche-912-technical-forum/624629-polo-engine-912-almost-done.html ![]()
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com Last edited by cmpski; 01-26-2023 at 05:49 AM.. |
I knew I had read about this car before. A few cosmetic changes maybe since I read about it years ago. Love it.
Thanks. More updates in the works. I'm looking forward to Rennsport.
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com |
Ok. I'll bite.
1973.5 911T Rebuilt from 2.4 to 2.9 liters now at: 215ft lbs @5,500 rpm / 245 hp @6,500 (at flywheel) ![]() Bodywork and Engine Rebuild completed by Automobile Associates, Canton, CT Engine: • LN Engineering custom 93mm Mahle Pistons for 9.8:1 compression ratio • LN Nickie Cylinders • Existing 70.4 stroke • DC 40 cam • Pauter rods • ARP rod bolts • Port heads to 35mm Exhaust • Port heads to 36mm Intake • Valves ground and lapped • PMO EFI system • Clewett EFI management system • Oil pump: rebuilt by Glenn Yee Motorsports • 3.2 Carrera front oil cooler with factory brass lines • High pressure fuel pump • ARP head studs • Engine Case machined by Ollie’s o Time-cert threaded inserts/ case savers o Shuffle pin case to reduce flex & movement o Reinforcing weld @ #3 cylinder o Oil squirters • Aluminum pressure plate • ARP flywheel bolts • Narrowed air deflectors • Club Sport engine mounts Transmission/ Shift • LSD transmission • Shift bushings replaced • NOS Aluminum pressure plate • RSR lightweight steel flywheel • Release bearing replaced Suspension/ Wheels: • Torsion bars: 21mm front / 27mm rear • Turbo Tie-Rods • Bump steer kit • Ball joints replaced • Elephant racing PolyBronze bushings front & rear • Elephant racing strut brace • Elephant racing front sealed monoballs • Corner balanced & 4 wheel alignment • Original 15x4.5” Fuchs rims • Michelin 205 / 60 R15 Tire Brakes: • Front: Brembo AM Calipers on original T struts • Rear: Original T brakes • Stainless steel brake lines. • Pedal cluster rebuild
...Oliver '73 911T: 2.9ltr w/ PMO EFI |
Very Nice Oliver what color is it ? Also are you sure the rims are 15x4.5 not 15x6 ?
What color blue is your car. It's a beauty with all the good stuff in the build. I'm building a Ultra Blau blue 69 for a friend.
There has been a lot learned about these engines in the last 10 years since my engine was built. Some POLO builders and Emory's engines are making 230 to 250 hp on engine dyno's at sea level. I looked into updating, but at this time I'll pass on spending the 30 to 40K to get to 230 hp. At 2100 pounds my car is a blast to drive. I can run with all stock long hoods from 2.0 to 2.4 liters and first gen Boxster's. This car was the first one and I think there are about 10 to 12 912 POLO's out there. Most in the US and Europe and one in Australia, and one somewhere in Asia. I spent about half and hour with Emory's son in law at LUF8. We walked each other around our cars. He is young enough to be my grandson. Really nice guy. His car is stunning like anything that comes out of Emory's shop. It's been fun developing this car. ![]()
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com Last edited by cmpski; 01-26-2023 at 06:33 AM.. |
Kind of Blue
Amazing. I now remember reading the Excellence article about your car and I'm completely in love. You nailed all the details. It must be a riot to drive.
The color is Dalmatian Blue aka Oxford Blue: paint code 329-9-2
You are correct... the rims are 6Jx15 (The 4.5x15's are the super rare early Fuchs rims)
nice to see another Dalmatian! here's mine (2.7 w/ RS P&C, early-S cam, webers)
Had posted earlier in this thread - car has been completed and now has >4K miles on it. Love it!
![]() 2,133lbs, 2.5MFI, 217hp and 201tq at the wheels (estimated 250hp and 232tq at the crank with 15% drivetrain). Gotta love narrow body, small displacement hotrods! Last edited by MyFlat6; 02-05-2023 at 11:08 AM.. |
Kind of Blue
I really enjoy your content on Instagram. Amazing machine!
