Help!! Car won't start
I just finished installing the engine back on my 911S 1974. I tried to start it ...and nothing. I run it and it started immediatelly. Turn it off and tried to started again and nothing!!
Starter was working fine before droping the engine, so i doubt it is the reason of the problem. I check and I do have voltage coming from the battery all the way to the alternator.
Also, following advice on a post on this forums, I disconnected the black (batttery) cable on the starter and turn the ignition a coupe of times,which supposedly cleans the solenoids of the starter...but nothing.
Any ideas on where to start ???
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 05-27-2005, 05:33 PM
copper's Avatar
Did you reconnect the engine ground strap? Check it, it could be loose.
How about the dizzy? Check the wires didn't pull out on you. But if by "nothing" you mean absolutely nothing, then it's something else.
What exactly is it doing when you try to start? Anything? Any noises? Is the fuel pump winding up? Is the starter going? Is the engine trying to turn over and won't?
Are you getting power at the starter?
Sounds weird. I'm sure with all the combined knowledge here, we'll figure it out for you, if you don't do it yourself first.
Take a break, then go back to it and go over everything to make sure your connections are all good and nothing's come loose.
Good luck
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 05-27-2005, 06:10 PM
Originally posted by copper
[B]Did you reconnect the engine ground strap? Check it, it could be loose.
I only dropped the engine, not the transmission. Is there a ground strap on the engine itself?
Sorry, what the dizzy??
You are right it is not nothing. Fuel pump is working and everything else seems. Just the starter is not moving at all, but I do have power there.
I pushed (run) the car by myself and it started immediatelly, so it is clearly something with the starter electrics...but I have no knowledge on that.
Thanks again
Mario
'15 GT3
Old 05-28-2005, 06:12 AM
78 STROSEK's Avatar
Check the small wire on the starter for voltage. It should have 12 volts when the key is turned to start. You can also short the large battery cable to the small wire to make the starter crank. If it cranks this way and will not crank with the key, the you have a wiring problem in the starter circuit.
Old 05-28-2005, 07:04 AM
