71 tub w/84 suspension...what rear shock?
I see lots of applications listed on the Pelican catalog for rear shocks.What shocks should I be using on my 71 that has 84 control arms?
Steve:
Since your Carrera aluminum trailing arms have a 14mm hole in them for the rear shock mounts, you would use a late-style rear shock that has the 14mm hole in the lower shock eye. Of course, you will need the 14x85x1.5mm bolts and washers.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thats what I needed to know...Thanks!
