cleaning carpets
While my seats are out of my 73 T for reworking and a short shift kit is being installed, I thought I would use the down time to remove and thoroughly clean the carpets that can easily be removed. They are not stained but seem matted down and a little stiff. I recently read shampooing with baby shampoo??? And what is best for the carpet pieces that are to difficult to remove and must be cleaned in the car. Thanks in advance!
Old 05-28-2005, 06:48 AM
While getting the driver seat bottom recovered at an upholstery shop recently I watched them clean some very dirty tan carpets from a 2 year old BMW 7 series. They had removed the carpets and used a power washer on them. Unfortunately I did not see what type of soap but what surprised me was using the power washer. Came out like new.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 05-28-2005, 07:02 AM
poorsha's Avatar
I used Turtle Wax "Power Out" professional strength carpet cleaner (it comes with a scrub brush on the can), and with a little elbow grease they came up as new (car is a 74 with tan interior).
I found that this stuff created a lot of foam and I had to keep removing most of it. I'm sure baby shampoo is better but this stuff worked for me.
I removed the pieces that are easily removed and the rest I just cleaned in the car (seats were out).
I am amazed at how good the carpet looks after 21 years.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 05-28-2005, 07:27 AM
Zeke's Avatar
Woolite is good, too. Both are mild soaps, not detergents, AFIK.
I used to have a shop near a detailer and he threw the carpets on the ground. washed them with a brush, hit them with the hose and then the shop vac.
I also like Tuff Stuff (I think that's the name, reddish spray can) for glued down carpets. Follow with a water soaked towel to try to keep the cleaning agents from building up. The just attract more dirt! (Same in your house carpet, make 'em rinse.)
Old 05-28-2005, 09:03 AM
randywebb's Avatar
power washer is not kind to the material - don't do it on your car
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-28-2005, 01:11 PM
Recreational User
porschenut's Avatar
I agree, don't use a power washer. Use a carpet deep-cleaning machine like the professionals use in your house with an upholstery attachment. You can buy a good one for around $100-150, or rent one.
Old 05-28-2005, 02:18 PM
Folex works.
CConnor
73E targa
89 Coupe
Old 05-28-2005, 02:44 PM
