gost's Avatar
Head gasket advice on 3.2
I have started work on my 85 3.2 with 120K on the clock and when I removed the alt/fan I noticed what looks like a gasket leak. Is this a sign of a blown head gasket? The car ran fine and the plugs are great prior to work start. I'm just doing basic maintenance stuff on her.
I will be adjusting the valves in the next few day's and am wondering if that will allow me to perform some sort of check on the head bolts or anything else you pro's recommend.
Just because I don't care doesn't mean I don't understand!
Gordon Ost
'85 Carrera Cab
'01 Durango 5.9 R/T
'00 Taurus SE- SO's canoe
'97 KTM 250EXC
FOND MEMORIES:
'68 Pont Ventura Conv 389w/trips
'99 BMW 323is
'71 TR-6 very first car
'73 TR-6 restored it-Concours winner
'67 Lincoln Conti-suicide doors
'70 Challenger-340-6pack slap stk
'69 Dart GTS 440-4bl-4spd
'73 Moto Guzzi Eldorado
Old 05-24-2005, 09:31 PM
Somewhere in the Midwest
MotoSook's Avatar
The 3.2 has no gasket or rings...it's a metal to metal contact. Check you head stud torque.
Old 05-24-2005, 09:37 PM
gost's Avatar
I assume I will have access to the head bolts with the valve covers off yes? Anything to watch out for or is it a straightforward torque wrench adj/check?
Thanks souk
Gordon Ost
'85 Carrera Cab
'01 Durango 5.9 R/T
'97 KTM 250EXC
FOND MEMORIES:
'99 BMW 323is
Old 05-24-2005, 09:45 PM
MotoSook's Avatar
Gost...yep it's pretty straight forward..with valve covers off. The leak is from the cylinder base shim...sometimes they seep. Being that you have have evidence of oil on top of the seam...it's a good idea to check....It's not a major issue if you studs are not broken and are torqued, but checking your head studs is easy.
Good luck.
Old 05-24-2005, 10:33 PM
gost's Avatar
Thanks for your input. My heart skipped a beat when I saw the seepage. Re-torque it is.Off I go!
Gost
Gordon Ost
'85 Carrera Cab
'01 Durango 5.9 R/T
'97 KTM 250EXC
FOND MEMORIES:
'99 BMW 323is
Old 05-24-2005, 11:10 PM
MotoSook's Avatar
Gordon, I just looked at the picture again, and it's not the base shims...I should have taken a better look. That's the head to cylinder seam...
That's likely combustion blow out....back to your other thread.
Old 05-28-2005, 04:03 PM
