chrisp's Avatar
Do calipers develop slow leaks or completely fail?
My calipers are original, never rebuilt. I don't want to have a massive failure due to age of seals etc. Will they totally fail or just start to develop sticky pistons, slowly leaking seals, etc.?
'83 SC
Old 05-28-2005, 05:23 PM
Usually they fail slowly over time. Sticking after periods of storage and or leaking when used again. Rebuild is easy and not very expensive unless pistons are badly corroded needing replacement .
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 05-28-2005, 05:45 PM
chrisp's Avatar
thanks.
'83 SC
Old 05-30-2005, 06:37 PM
Now in 993 land ...
aigel's Avatar
If they are indeed from 83, just put a rebuild on your to do list next time you would bleed the brakes or do other brake work like new rotors or pads ... a rebuild kit is in the tens of dollars. John is correct, I don't know of any catastrophic failure. It is a slow deterioration, so there is no hurry if your brakes are ok now.
George
81 SC (sold)
Old 05-30-2005, 11:53 PM
chrisp's Avatar
How long can a first timer (to brake rebuilds that is) expect it to take per caliper? I have access to compressed air.
'83 SC
Old 05-31-2005, 07:03 AM
Somatic Negative Optimist
Gunter's Avatar
Do a search for the rebuild project on this board, it gets involved. What happens with age is that the pistons freeze (rust-up) inside the calipers meaning: The pistons do no longer retract properly meaning: The pads are contacting the rotors all the time slightly meaning: Heat and a little loss of HP. Get the Bentley manual or, take the calipers off and go for a rebuild set/exchange.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-31-2005, 08:26 AM
B D B D is offline
B D's Avatar
First one will always take the longest, you will playing with clamps and spacers to get the pistons almost all the way out together. After you got the steps down around 30 minutes per caliper to remove the pistons, seals, and put them back together. If they are stuck and in bad shape it may take longer.
The tech article on Pelican is a great resource.
68 911L
Old 05-31-2005, 08:28 AM
gost's Avatar
Yes first one is the longest. I just removed mine out of an 85 and used the compressed air and C clamp method and it worked great. Make sure you use a small block of wood and put it between the pads when you are about to pop them out. They poped out like bullets on mine. Clean only with alcohol, brake cleaner or hot water with laundry detergent, nothing else no engine degreaser and no parts washer solvent, I just went through this so listen!
Good luck
Just because I don't care doesn't mean I don't understand!
Gordon Ost
'85 Carrera Cab
'01 Durango 5.9 R/T
'00 Taurus SE- SO's canoe
'97 KTM 250EXC
FOND MEMORIES:
'68 Pont Ventura Conv 389w/trips
'99 BMW 323is
'71 TR-6 very first car
'73 TR-6 restored it-Concours winner
'67 Lincoln Conti-suicide doors
'70 Challenger-340-6pack slap stk
'69 Dart GTS 440-4bl-4spd
'73 Moto Guzzi Eldorado
Old 05-31-2005, 08:50 AM
HI ChrisP,
I agree with gost and BD that the first one is the longest. Took me about an hour and then about 30 minutes. Was really anal on the first one since I had never done it before. In the end it was very easy from what I had anticipated.
Be careful with compressed air. A tire pump was sufficient in my case. Used a wide inflating attachment for beach balls worked and do use a piece of wood in between the pistons as they do pop out with considerable force. I just made a 20 degree template with cardboard to align the pistons and had great results.
Have fun!!
Quincy
Fountain Valley, CA
'83 SC, '13 P-GTS
"Air cooled, fountain pen guy, living in a water cooled, iPhone world"
Old 05-31-2005, 11:02 AM
Added safety precautions.
Wear eye protection and cover the caliper with shop towels while applying air pressure. You do not want brake fluid spraying into your eyes, or worst yet, onto your paint job.
Sherwood
Old 05-31-2005, 01:41 PM
gost's Avatar
Sherwood is absolutely correct. Forgot to mention that. Good call. I got a misty fog lingering for a few seconds as well..cooool.
Gordon Ost
'85 Carrera Cab
'01 Durango 5.9 R/T
'97 KTM 250EXC
FOND MEMORIES:
'99 BMW 323is
Old 05-31-2005, 08:19 PM
