Will this make 210Hp?
I was reading Doug's thread on Early hot rods, and saw that one of the cars on there was a 2.4S that changed the P&C and made it a 2.7
Question: Can I change the P&C on my 2.4T to make it a 2.7
and about 200 or 210hp or does more need to be done?
I think that I would be happy with 190hp, anything over the 155hp I have now.
Car in Question
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 05-31-2005, 02:34 PM
With RS pistons and cylinders or equivalent, yes.
However, you'll have to enlarge the crankcase spigots to accept the larger cylinders, so it's not exactly a bolt-on upgrade.
S cams and modified MFI are also needed. Your port sizes should also be enlarged to S-equivalent; not sure about valve size.
This upgrade is described in B. Anderson's book as well as Waynes rebuilding manual.
With machine work, gaskets and new parts, you're looking at around 4 thou.; add someone's labor to D&A.
Sherwood
Old 05-31-2005, 02:44 PM
Stressed Member
Scott Clarke's Avatar
Valve size is the same. You will need to recurve the distributor.
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 05-31-2005, 02:57 PM
I seems better to just buy a 3.2 for about $6000
2011 M3 4Door
Old 05-31-2005, 04:54 PM
